Weird squeal at startup..
Old Jan 9, 2009 | 09:27 PM
874runnersr5's Avatar
Well, its starting to bother me now.. heres the run down
Nothing made noise besides my power steering when it was cold before i did my timing chain.
*after* i did my timing chain, i put a new alternator v belt in that i had..
now, at startup for the last couple months ive been getting this weird squeal..
sounds like a belt, but.. how can i test/verify that the belt is no good?
Could it be a alternator bearing? some type of bearing?
its just kinda embarrassing this squeal sound at startup and everyone looks at me...
anyone point me into some type of direction would be awesome..
Old Jan 9, 2009 | 09:41 PM
tommy316's Avatar
Sounds like a loose belt. Make sure you dont have too much play in either the power steering belt or the alternator belt.
Old Jan 9, 2009 | 09:42 PM
Tubbyfatty's Avatar
Yep, check yer belts.
Old Jan 9, 2009 | 09:48 PM
PDX_1ton's Avatar
Probably your belt since you changed it. But do this just for fun. Next time you start the truck, push the clutch. If the sound changes or goes away.. Well you now know where it is around.
But most likly your belt
Old Jan 10, 2009 | 07:48 AM
alright today ima check the belts, retighten everything and clean anything up..
Old Jan 10, 2009 | 07:59 AM
Cyberman's Avatar
A little late, but if you spray each belt with WD40 while it's running, you'll find out which one it is. My power steering belt squealed like crazy for a while.
Old Jan 10, 2009 | 08:06 AM
DanStew's Avatar
Check your water pump for leaks. I have the same squeal and i couldnt figure out what was making it. I was doing the alternator and noticed my pump weeping right on the crank pully. So at startup it would squeal for a second. Pisser is the water pump is brand new
Old Jan 10, 2009 | 09:31 AM
hey cyberman, ive herd this trick before, how do i do so? Just spray each belt at the same time? or at different times? on the crank pulleys right?
danstew, i havent seen anything leaking from the wp area
Old Jan 10, 2009 | 09:40 AM
NicCantDecide's Avatar
If you want to figure out which one it is, I'd suggest not spraying the crank pulley.
PS: spray the pulley at the powersteering pump...
alternator: spray the alternator pulley
A/C: spray the A/C pulley
Old Jan 10, 2009 | 10:57 AM
ah i gotcha..
i dont think i have wd40!
lame..
Old Jan 10, 2009 | 01:24 PM
LS1Steve's Avatar
I don't know if you want to use WD40.... that may silence it but could cause some slippage. Your local auto parts store should carry a can of belt dressing to quiet it down.
Old Jan 10, 2009 | 01:42 PM
casey.eyman's Avatar
You can also use baking soda in a pinch to quiet a squealing belt.
Old Jan 10, 2009 | 01:56 PM
but its only squealy at startup, doesnt matter if i ran it for 2 hours or 5 mins.
It just squeals up for a bit then shuts up... hmm....
Old Jan 10, 2009 | 02:08 PM
bigt's Avatar
push the belt down a bit if it goes more then a little its too loose.tighten with nut.. they strech after a little bit
Old Jan 10, 2009 | 02:21 PM
to be honest, i remember rushing the alternator belt crap because it was like 1am..
it was hard to get tension on it,hold the bolt on one side with a wrench and use a ratchet to tighten the bolt
Old Jan 10, 2009 | 02:34 PM
bigt's Avatar
hrmm you just need one socket to make tension .. atleast on mine you do there is an adjuster nut...
Old Jan 10, 2009 | 04:06 PM
il check tomorrow for sure, i need to flush my ps too.
i hope i got enough atf.
Old Jan 10, 2009 | 06:40 PM
LS1Steve's Avatar
on startup it is cold. after a few seconds the friction heats and softens the rubber
Old Jan 10, 2009 | 06:43 PM
yeah im aware of that, im was just trying to add more info.
Old Jan 11, 2009 | 11:58 AM
fixed it!
so it was the alternator belt thing, i didnt think it was that loose but i tighten'd it up pretty good and started her and no noise!
yaya..
gave my ubolts for the rear leafs and everything else a good shot of pb buster to.
