drain t-case for seal replacement?
Old Jan 9, 2009 | 08:17 AM
toyNG's Avatar
After months of dealing with oil being sprayed under my truck and onto the driveway, I'm finally getting around to replacing the seal where the rear driveshaft meets the t-case.
Do I have to drain the t-case prior to removing the driveshaft? Or will simply jacking the rear end up push the t-case oil forward enough to prevent it from spilling out?
Old Jan 9, 2009 | 09:39 AM
zlathim's Avatar
You can probably get away with draining just a little bit of oil out to do the rear output seal, but why not just use this opportunity to freshen up the oil completely?
Old Jan 9, 2009 | 09:55 AM
allnmstkn313's Avatar
If you angle the truck nose-down, you will not need to drain it at all.
Old Jan 9, 2009 | 10:28 AM
swapped89's Avatar
i would just change the oil while your down there it only takes a couple quarts. just drain it. change the seal. put the drain plug in and fill the transfercase till it pours out the fill plug hole.
Old Jan 9, 2009 | 11:02 AM
toyNG's Avatar
I just replaced the fluid about 2000 miles ago, so there is no need to change it again.
I guess I could drain and then refill with the same oil, but that would entail cleaning out my drain pan...and I'm lazy
Old Jan 9, 2009 | 11:45 AM
leebee's Avatar
drain it into a clean container through some cheesecloth. reinstall once the seal is replaced. no need to try and clean a non existent tcase drain pan.
lee
Old Jan 9, 2009 | 12:42 PM
Jay351's Avatar
x2
Drain it, and reuse. I did the same thing when I did the front output seal on the transfercase.
just need a 24mm socket to drain and fill the fluid.
Old Jan 9, 2009 | 12:50 PM
toyNG's Avatar
lee
By drain pan, I was referring to the container I'd be draining the old fluid into. Maybe I will clean it...although I'm not looking forward to it
Old Jan 9, 2009 | 01:11 PM
Jay351's Avatar
Just grab a handfull of paper towels (I keep rolls of those blue shop towels around) and wipe it clean... No biggie
I drained mine into empty gear lube bottles
Old Jan 11, 2009 | 10:32 AM
toyNG's Avatar
Well I think I got the wrong part from the dealer. My first suspicion came from the price. The part I got cost me $27.58, while other people seem to be saying it should cost around $10. The part I got is called Seal Type D, however, I believe the one I am looking for is called Seal Type T. Can anyone verify this?
Here are some pics of the part I got. I know it's kinda hard to see the actual seal, but I didn't want to open it yet, since I'll probably have to return it.
Old Jan 11, 2009 | 11:46 AM
dntsdad's Avatar
http://www.toyodiy.com/parts/
You check part number from here. Enter your vin.
Also, I find its always better to give the dealer your vin for parts rather than just year, model, motor, etc.
Old Jan 11, 2009 | 12:55 PM
My99's Avatar
As far as draining the fluid, I'm not sure why anyone would recommend you do this, unless you simply want to change the fluid. You will have a bit of fluid run out from where you pull the old seal out (have a little pan ready), maybe about 6 oz max. But the seal is higher on the T-case than the actual fill plug.
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Edionne13
Jul 9, 2015 01:59 PM
Gamble_STi
Jul 7, 2015 07:54 PM
