22re idle and rev issues
Old Jan 13, 2009 | 08:22 AM
ronnie4's Avatar
If anyone has any suggestions on what the problem could be, I'd greatly appreciate it.
Description:
When I first start the truck it will start up and idle just fine. If i try to take off in first itll stall and die, however if i put the clutch in and try to take off at 3000 rpm itll go and not die. This issue seems to go away after the engine warms up. The truck also won't go above 3-4000 RPM (varies, wont stop at the same RPM each time), itll get to a certain RPM and the engine will just "kick" and the check engine light will come on and go off after it is done kicking.
All sensors are pluged in and no loose vaccum lines. I also checked spark and timing and that seems to be working fine.
Edit: the truck is a 87 4runner, 22re manual transmission
Old Jan 13, 2009 | 09:13 AM
thook's Avatar
Checking the ECU code/s would help...
http://www.off-road.com/toyota/tech/codes/index.html
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
mengquis
Jul 13, 2015 10:39 AM
Jnkml
Jul 6, 2015 01:20 PM
