3VZE Hard to Start...Clicking sound
Old Oct 20, 2006 | 02:15 PM
95ToyotaPU007's Avatar
My 95 PU w/3VZE is now taking longer to start. I am worried this will greatly shorten the life of my starter.
I have looked into the CSI (cold start injector) threads and will see what happens once the inspection is done.
But there is one thing I have noticed when I try to start the PU. At the beginning of the cranking, there is a clicking sound coming from under my glove box. It only clicks once or twice at the beginning of each crank (with no successful start). I have never noticed this before.
After several attempts the engine finally starts.
I have also noticed it takes longer to start in colder weather since I was in Durango CO last week (Oct 14) and it took a while to start in the morning.
I know this (CSI) has been beaten to death but does anyone have any suggestions about the clicking sound?
Thanks in advance.
Old Oct 20, 2006 | 02:50 PM
Guardian_Saint's Avatar
clicking noise coming from the pessenger when you are trying to start the truck? So it might of be your starter problem or low battery, either one. Mine will do the same thing in the morning..
Old Oct 20, 2006 | 03:28 PM
Firefightertaco's Avatar
its your starter
Old Oct 20, 2006 | 04:31 PM
I need to make it clear that the engine is turning over fast, like a normal start up.
Its 2-3 seconds into the turning that I hear this "click" from under the glovebox, while the engine is still turning over fast. It does not sound like its coming from the outside of the cab.
Old Oct 20, 2006 | 09:14 PM
dcg9381's Avatar
Relay?
Old Oct 20, 2006 | 10:14 PM
Elton's Avatar
make sure all ur battery cables are tight and if that dont help it sounds like it could be the starter contacts
Old Oct 20, 2006 | 11:31 PM
Bassinfool's Avatar
If your truck is taking 2-3 seconds to start, it's either battery or starter. my 3vz-e starts in about .5 seconds
Old Oct 21, 2006 | 12:05 AM
Thanks. I will look into the suggested fixes.
Old Oct 21, 2006 | 03:52 AM
HAVOC's Avatar
That sounds like the "circuit opening relay". It should be bolted to the pass. kickpanel, near the ECM.
It could be on it's way out.
Old Nov 29, 2009 | 06:59 PM
Sanchez's Avatar
Mine was clicking on occasion, then it worsened and would not start on occasion. Replaced an old starter and some wiring. Only to realize that it was in my (ignition key cylinder area)wiring. At least that's what I believe. Installed a push button so that it wasn't going let me down again...
Old Nov 29, 2009 | 07:42 PM
MaK92-4RnR's Avatar
its your battery, or your starter...
Old Nov 29, 2009 | 08:15 PM
txhal9000's Avatar
had the same problem with clicking from glovebox area (mine wouldn't start at all)...changed the starter...no fix....then changed the $6 wire from battery to starter----FIXED!!
Old Nov 29, 2009 | 09:18 PM
abecedarian's Avatar
Holy old thread batman.
jashoeuh
Nov 18, 2024 08:08 AM
theking11863
Mar 19, 2016 09:36 PM
ahriman
Aug 1, 2015 10:38 AM
Sr5crawler
Jul 31, 2015 12:32 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
