Throwing a code 12 ,25, and 26
Old Jun 14, 2012 | 08:50 PM
jtbonds13's Avatar
Does anyone have a suggestion on where to start first on the code 12? Also why would I be getting a code 25 and 26 at the same time?
Old Sep 16, 2012 | 05:10 PM
SeeBeeAre's Avatar
im having similar issue any feedback ?
Old Sep 16, 2012 | 06:42 PM
jtbonds13's Avatar
Never got any feedback. I did disconnect the battery and the code 12 stopped popping up but i still have a 25 and 26 at the same time. Those two only come up when I am driving at highway speeds.
Old Sep 17, 2012 | 08:02 AM
SeeBeeAre's Avatar
mine seem to pop up after hard acceleration to breaking or slowing to turn off highway !!!! , my light used to shut off but it seems to be steady today, im gonna walk through the book and i will tell you what i find,
Old Sep 17, 2012 | 08:49 AM
jtbonds13's Avatar
Does it effect the performance at all?
Old Sep 17, 2012 | 01:09 PM
SeeBeeAre's Avatar
i think im getting bad gas milage about 200 miles to a tank and i noticed on a road trip after it was good and warm it would die at stop signs, and run real rough for a min after i restarted it
Old Sep 17, 2012 | 01:42 PM
jtbonds13's Avatar
I think i am getting bad gas mileage but that is it.
Old Sep 17, 2012 | 03:35 PM
SeeBeeAre's Avatar
by chance do you know what these sensors are ?
Old Sep 17, 2012 | 05:04 PM
jtbonds13's Avatar
where are they located
Old Sep 17, 2012 | 06:54 PM
SeeBeeAre's Avatar
on the back of the throttle body close to the firewall the one without a wire the wire was loose and coroded it also looks like the conector on the wireing harness is broken off .... i cleaned the connection and so far no check engine light... gonna reset the ecu tomorrow and see if it fixes it???
im hoping its the temp sender telling the engine to use the egr system causing a lean and rich fail but i have a feeling its a long shot.... While going through it loos like the previous owner replaced a lot of the system already. but again im not to sure
Old Sep 18, 2012 | 03:23 PM
SeeBeeAre's Avatar
does your truck have a cat ?
the stealership said check o2 and maf sensor
Old Sep 19, 2012 | 07:35 AM
SeeBeeAre's Avatar
now im getting to the nitty gritty ....
light came on again got no answers from parts store and a little from toyota i re plugged in that wire on the above pic to the sensor there only one wire to it. i believe its a water temp sensor according to the diagrams i have found
after i replugged in the wire the second time seems to have shut off the light .... more info to come if the light comes back on but below are some links that helped me with the chasing down of the system i hope they help you too
Diagnostics scroll down to code 25, 26 there are refrences to page numbers that have broken links
here is the pages its refering to
oops above is for 22r
diag
pages
test for O2
Part location diagram
Old Oct 17, 2012 | 07:23 AM
SeeBeeAre's Avatar
i got the check engine light out.... though it was a new engine that did it let me tell you what i found.... in the above picture with the sensor above there was a cheap wire connector attached to the original blue wire to a thicker black and yellow new wire....
i cut and soldered that connection also there was an exposed wire to the number 3 cylinder injector.... cleand and fixed that connection
in the number 6 valve i found a bolt, a bolt which i believe sat in the intake plennum and rattled its way down there and caused engine to not function any more
also compression was low in three cylinders and the intake was coated in oiil and carbon buld up.... the intake tube was also filled with a gooy gunk
conclusion
I believe the bolt disrupted the air flow to the number 6 cylinder causing an occasional miss firing causing a lean and rich problem in the engine ....
with engine running get a stethascope and listen to each injector and see if it ticks inside ....
If i were you i would pull the plennum and clean out the inside of that and your intake manifold.... inspect injector wiring and see if anything needs to be cleaned up also check the wiring on the sensor in the pics above .... make sure nothing falls into the intake plennum and look towards the valves and see if there are any obstructions to the cylinder
I hope this helps
Geoff
jb451
7
Oct 7, 2022 06:58 AM
muddpigg
Nov 2, 2015 05:36 AM
PureTacoma_Tundra
Vendor Advertising
Sep 6, 2015 06:38 AM
Badfish740
Sep 4, 2015 04:21 AM
moparbay
Sep 3, 2015 12:48 PM
