spindle/hub interchange
Old Mar 17, 2015 | 07:25 PM
hotrodchriz's Avatar
Are the 2wd and 4wd spindle/hubs interchange on 2nd gen 4runners being that the 2wd 4runner frame/suspension Is the same as the 4wd?
Old Mar 18, 2015 | 02:29 PM
wyoming9's Avatar
Red face
Well the 2WD hub is 5 lugs the 4x4 is 6 lugs
Also the 4x4 spindle is hollow where the 2wd is solid.
I have never seen a 2wd up close and in person.
My guess would be no But it is a guess.
Old Mar 18, 2015 | 03:58 PM
toyota4x4907's Avatar
2wd 2nd gen 4Runners are 6 lug. 2wd trucks are 5 lug.
I'm fairly certain that the 2wd and 4wd hubs/spindles on 2nd gen 4Runners are the same. But I could be wrong....
Old Mar 18, 2015 | 05:21 PM
Yeah the 2wd 4runner from my understanding share the same chassis as the 4wd 4runner. So that's why I am trying to see if the spindle/hubs are the same. To me they look the same, the only difference is that the 2wd has a dust cap where the cv enters and was wondering if I can just pop the cover off and slide the cv in there.
Old Mar 19, 2015 | 07:47 AM
rattlewagon's Avatar
Can you take some close up pictures? See if you can get one of what under the dust cap.
Old Mar 19, 2015 | 08:02 AM
scope103's Avatar
The Parts catalog doesn't differentiate between 2wd and 4wd (though "model," like "Deluxe" and "SR-5" might hide that.)
Oops! This is not quite right. Depending on the Model code, a different part number is sometimes called for. A model code is like RN85 (22re) or VZN110 (3VZE). Alas, I can't find a listing of all the number part of that code. I believe it has to do with bed length mostly. I don't believe it is controlled by 4runner vs. Pickup. When using a web site like the one cited, use the correct description of your vehicle, and read the call out for the part number for model limitations.
By "spindle" I assume you're talking about the Steering Knuckle. http://www.toyotapartsoverstock.com/...320135040.html The parts catalog gives one part number (per side) for almost every model. Just to be sure, look under 'fitment' to see that your donor and recipient are both listed.
Old Mar 19, 2015 | 03:32 PM
wyoming9's Avatar
Red face
Wow learned something new!!
Meaning I can get these parts off 2wd trucks no one wants.
You the man!! Scope103!!
Old Mar 19, 2015 | 06:03 PM
Thanks scope103, that helps a lot. Remember Wyoming, only the 4runners, not the pick ups.
diingodog
Jan 11, 2018 10:39 AM
icentropy
Sep 10, 2015 05:03 AM
Gutted91
Aug 23, 2015 11:58 PM
TransAmBandit
Jul 28, 2015 11:30 PM
TDonkey
Jul 26, 2015 10:14 AM
