Am I going crazy?
Old Mar 16, 2015 | 08:52 PM
Swim's Avatar
Am I going crazy?
I just rebuilt my Aisin hubs. I was told they were IFS... but I'm starting to question that....
I have rebuilt them 2 times each... both times I followed this
http://forum.ih8mud.com/threads/rebu...ebuild.149776/
and this
http://personal.utulsa.edu/~nathan-b...14freewhee.pdf
No matter what I do the hubs will not allow the CV axle to freewheel.
It doesn't appear that I have the gaskets. Is the tolerance so tight that they will not disengage without the use of the gaskets?
Does anyone have any other ideas here?
Does anyone have a photo of the follower prawl from an IFS and a SFA? I'm trying to see if I have the SFA prawls in an IFS hub... can that even happen???
Thanks!!!
Old Mar 16, 2015 | 09:14 PM
millball's Avatar
Its not the lack of gaskets.
Likely to be a problem with how the springs are seated that push and pull the locking collars in and out.
I think that SFA and IFS hub parts are all interchangeable except for the locking collars.
The locking collars have different internal spline counts because the outer drive axle stubs are splined differently on IFS and SFA.
Old Mar 16, 2015 | 09:20 PM
Gevo's Avatar
I think millball is correct about the spline count. I am not sure however if the one with fewer splines (solid axle version) would somehow fit over the IFS setup just ao that you wouldnt notice. I think you would notice.
No offense, perhaps something is not put back as it should be? If you take pictures of the insides in sure the experienced people on here can spot whats not right.
Old Mar 16, 2015 | 09:56 PM
Swim's Avatar
I'll post some photos tomorrow. This is not my first rebuild on hubs.... but it's the first time I've ever had problems..
DHWRIGHT's Avatar
very first time i did my wheel bearings i packed too much grease in mine and they would not disengage.
Old Mar 16, 2015 | 10:15 PM
millball's Avatar
Too much grease can definitely jam 'em.
Old Mar 17, 2015 | 06:31 AM
Swim's Avatar
Here are some photos of the driver side
Old Mar 17, 2015 | 06:42 AM
Gevo's Avatar
I'm not an expert on this, but I did notice one thing which looked funny to me.
In this picture, it looks like the big spring is compressing into itself, shouldn't a proper working spring stack instead of one layer pushing into the other? Perhaps the springs are worn out/stretched.
Old Mar 17, 2015 | 06:56 AM
thefishguy77's Avatar
I just saw that as well. I will head down to my garage and pull one of my spares apart and see
Old Mar 17, 2015 | 07:14 AM
RJR's Avatar
RJR
I can't tell you just what's wrong, but those don't look right. The locking mechanism is sticking out too far from the mounting plate, I think. When it's in the "Free" position, everything should be tucked inside the mounting plate and the spring should not be showing at all. The way it is, there's no way the locking collar (the part with the splines) is going to slide back far enough to release from the hub.
I think you'll have to visit one of the web sites where someone shows how to overhaul these things and study just how they go together.
Old Mar 17, 2015 | 07:33 AM
Gevo's Avatar
RJR, the spring tucking into itself would cause the outer ring to sit against the housing (as seen in the pic) and not allow the whole assembly to tuck into itself as you said.
Old Mar 17, 2015 | 07:55 AM
RJR's Avatar
RJR
I think you're probably right, Gevo. As I recall when I overhauled mine, there are a couple of ways to assemble that spring, and only one of them is the right way. If you do it wrong it doesn't allow things to go together all the way properly. I would guess the spring is in wrong somehow. or as you say, is mis-shapen.
Old Mar 17, 2015 | 08:42 AM
Swim's Avatar
Hey guys,
Thanks for the input. I removed the large spring and tried to mount it up to see if the spring itself was the issue. I'm still not able to freewheel. Which leads me to believe it is the follower prawl spring or the orientation of the follower prawl.
Anyone else have any ideas. I'm stumped.
Old Mar 17, 2015 | 08:58 AM
Gevo's Avatar
So, when you have the spring out and in free position, is everything tucked in as we were suggesting it should be? Without the spring, does it tuck into itself?
Old Mar 17, 2015 | 09:11 AM
Swim's Avatar
It doesn't tuck any more than with the spring
Old Mar 17, 2015 | 09:16 AM
JasonYota's Avatar
Do you have the spring on the correct way? Remember one end is flat and the other is angled. It's been awhile since I rebuilt some I had
Old Mar 17, 2015 | 10:31 AM
RJR's Avatar
RJR
Check out this thread, especially how the spring goes in. It should get you where you need to be. Everyone's right, the key is getting the spring installed correctly.
https://www.yotatech.com/forums/f116...ild-up-158644/
Old Mar 26, 2015 | 11:15 PM
millball's Avatar
Was there a successful resolution to this??
Old Mar 31, 2015 | 03:53 PM
Swim's Avatar
Nope. Still running them locked.
pickle6415
Apr 14, 2021 06:20 AM
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
live4soccer7
May 11, 2016 06:52 PM
primordialbeast117
Dec 19, 2015 12:23 PM
83
Sep 27, 2015 04:13 PM
