help with tranny issue...
Old Mar 9, 2015 | 07:38 PM
martinezoi's Avatar
So I have an issue with my 88 4runner 22re 5 speed. One first and second gear(havent tried 3rd or 4th), if accelerate to high past 3k the truck goes out of gear. I say that it goes outta gear cause what happens is that it will suddenly rev high.
Is a sign of a bad clutch, slave cylinder, syncros, throw out bearing, all the above or something else???
Thanks inadvance
Old Mar 9, 2015 | 08:02 PM
Shady Cadence's Avatar
If you back off the throttle to bring the rpm down, does it seem to be back in gear, or do you have to move the shifter?
Old Mar 10, 2015 | 03:49 AM
martinezoi's Avatar
I usually put in neutral and if its on first I just shift to 2nd, if on 2nd I put in on neutral and then put it back to 2nd.
This only happens when I drive it to the higher rpm which I hardly ever do. Daily driving it, I have no issues
Old Mar 10, 2015 | 04:22 AM
JasonYota's Avatar
Originally Posted by martinezoi
I usually put in neutral and if its on first I just shift to 2nd, if on 2nd I put in on neutral and then put it back to 2nd. This only happens when I drive it to the higher rpm which I hardly ever do. Daily driving it, I have no issues
That still wasn't clear. Does the shifter actually jump out of gear? Or is the shifter staying in gear and the clutch slipping?
Old Mar 10, 2015 | 05:31 AM
martinezoi's Avatar
Shifter stays in gear
Old Mar 10, 2015 | 06:08 AM
JasonYota's Avatar
Clutch is slipping. How many miles are on it? Usually it will start to slip in higher gears. If yours is slipping in 1st and 2nd it's on its last leg.
Old Mar 10, 2015 | 07:45 AM
bswarm's Avatar
When you replace the clutch, inspect the shifter seat when you pull the shifter. Marlincrawler makes a better seat & socket.
Old Mar 11, 2015 | 12:18 PM
martinezoi's Avatar
thanks guys for the replies, I did already replace the seat with marlin crawler one. Gonna get me a tranny jack and I guess tackle it on...and the rear main seal since i'll be there
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
