shifter probs with body lift
Old Feb 18, 2009 | 08:46 PM
Ol'Lee's Avatar
the truck i purchased has a 3inch body lift on it and it had ripped shifter boots on it and i got another set from the local junk yard but with them installed the truck jumps out of 2nd 4th and reverse, was wondering if there is a way to fix this or if someone else has had this problem. thanks in advance
Old Feb 18, 2009 | 09:07 PM
toyNG's Avatar
almost all the information you'd need can be found here http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml
for the shifters, you can try inverting the boot, or cutting the boots in the right places can reduce the stress on the boot, which will reduce how hard it pulls on your shifters.
Old Feb 18, 2009 | 09:08 PM
swapped89's Avatar
They probably didnt extend the shifters when they did the body lift. Or you might need to get rid of or mount the lower black part of the shifter boot under the tunnel instead of the on top. There is too much rubber in there to let the shifter sit in gear. all that rubber is forcing the shifter out of gear. or the shifter seat and socket could be worn.
If the shifters were extended and all the rubber boot is not the problem try these shifter socket and shifter seat from Marlin Crawler.
http://marlincrawler.com/transmissio...-shifter-seats
http://marlincrawler.com/transmissio...hifter-sockets
if none of that helps your prob may be more complicated. shifter forks or somethin in the tranny.
Old Feb 19, 2009 | 03:59 AM
934rnr's Avatar
The other way around it is basically relocating the shifter boot plate. I have done this in the past with short body-lifts. Basically you move the plate until it doesn't bind when you shift then drill new screw holes in the plate and then secure it back down.
Old Feb 19, 2009 | 04:36 AM
dropzone's Avatar
Fossilized
sometimes you also need to extend the hole if you don't dog leg the shifter. Your transmission is 3" lower than it was intended therefore not allowing the shift to go through the range of motion it was orginally designed for.
check your transfer case selector too, I bet you might have a similar problem with it knocking itself out of 4WD.
Old Feb 19, 2009 | 04:54 AM
Ol'Lee's Avatar
alright guys thanks ill give it a shot
Old Feb 19, 2009 | 05:34 AM
highway's Avatar
on my old 86 i heated the shifter and bent it a little and it worked ok for me.
Old Feb 19, 2009 | 05:42 AM
4Crawler's Avatar
This section of the web page will give you several options:
- http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Several shown below:
Trim the shifter boot base plate:
Invert the shifter boot:
Relocate the shifter boot forward or back:
Old Feb 19, 2009 | 06:13 AM
Ol'Lee's Avatar
thanks 4crawler i inverted the inner boots and moved the plate back behind the plastic inserts and drilled new holes and took it for a test drive so far feels like it will work, still feels a little stiff in 2nd and 4th so idk how it will do offroad but as of now works great, thanks
Old Feb 19, 2009 | 06:37 AM
toyNG's Avatar
mine felt a bit stiff in 2nd gear for a while. But it wasn't bad enough that I worried about it popping out of gear. It broke in after a while. Now it pretty much feels like all the other gears.
Old Feb 19, 2009 | 06:53 AM
4Crawler's Avatar
If it is still stiff in 2 and 4, move the boots back farther. 2 and 4 are on the back side of the shift pattern, so moving the boots back farther could make those work better.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
