Question for the troubleshooting guru's
Old Feb 20, 2009 | 02:50 PM
neoworm0's Avatar
When I had a 3.slow in my truck it would occasionally die on startup. Usually only when it was cold but once when it wasn't. After it died it would always fire right back up and run fine. Sometimes the problem would go away for months. Usually i the summer it was fine.
On one 500mi trip in the winter it shut itself off 8 times on the highway, again it started right back up everytime. It would throw igntion related codes. 14 (igniter) etc.
I drove myself nuts trying to solve this. I finally gave up since I was doing a 3.4 swap anyway. I figured that would solve it.
Sooooooo.... the 3.slow is gone AND the EXACT same condition is present.
So my question is:
What could cause a code p1300 (3.4 OBDII now) that isn't related to the engine or the ECM because all that has been CHANGED?
Any ideas? Thanks.
Old Feb 20, 2009 | 03:06 PM
jpmountainboy's Avatar
do you change the igniter in a 3.4 swap??
Old Feb 20, 2009 | 03:10 PM
fireman1559's Avatar
sounds like what my iginiter did when it went out but it didnt start up again it would try to die and iwould floor it and that would bring it back and by the time i got to a place to turn around it died and wouldnt fire it would crank but not start so u might want to check that
Old Feb 20, 2009 | 03:15 PM
neoworm0's Avatar
The igniter gets changed with the swap. EVERYTHING ignition related to the 3.0 is GONE and replaced with the 3.4 stuff.
I don't think it is anything under the hood of the truck. Think firewall back with the exception of the ECM. Thanks. MAybe fuel system??
Old Feb 20, 2009 | 03:38 PM
abecedarian's Avatar
P1300 is igniter circuit malfunction: no IGF signal to ECU for 6 consecutive IGT attempts while engine is running.
I might say check the condition of, or add to, the engine and igniter module grounds- if the engine grounding is intermittent, cylinders will misfire and the result would be no IGF signals.
Old Feb 20, 2009 | 03:47 PM
neoworm0's Avatar
Thanks, all the grounds are fine. They were all redone when the 3.0 was in and again they were all redone when the 3.4 swap was performed. Everything is definitely grounded. Checked and double checked.
I really don't think this is the igniter. I think it is something else that is causing it to throw an igniter code. Any more ideas? Worn out ignition/key cylinder. What do you think? I tried wiggling the key around but that didn't cause it. It is really wierd that it seems to be temp. related as well.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
Avenged
Jul 9, 2015 07:55 AM
