truck harness help
Old Feb 15, 2009 | 04:19 PM
needsomecam's Avatar
truck harness help
pictured below is the very left side wiring harness from the dash of a 93 4runner 4wd automatic:
im looking to find out what prong is the tach wire. hopefully someone could tell me
and just in case the color is bad here is the color of the wires from left to right
1. green w/ red tracer
2. green w/ white tracer
3. yellow w/ black tracer
4. green w/ yellow tracer
5. black w/ red tracer
6. black
7. yellow w/ green tracer
8. green
9. black w/ orangish brown tracer
10. another yellow w/ green tracer
11. another green
12. white w/ green tracer
thanks.
Old Feb 15, 2009 | 06:41 PM
scope103's Avatar
According to the FSM, the tach is a black wire to pin 7 of the A (12-pin) connector. You might be counting your pins from the wrong end.
Old Feb 16, 2009 | 04:15 AM
Flash319's Avatar
It is the second one in from the brake between the 2 sections on the left section. I had the same truck. The pin did not have a wire on it in mine. Connector D number 7 pin. The plug closest to the driver side window.
Old Feb 16, 2009 | 07:34 AM
wow these posts were exactly what i was looking for. Thank you so much both of you cant wait to do this swap
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
scottt80
Jul 1, 2015 12:13 PM
greenbuggy
Jun 28, 2015 10:40 AM
TheManOutside
Jun 18, 2015 03:32 PM
