Heater only works when accelerating?..
Old Feb 10, 2006 | 10:19 AM
AW1090's Avatar
Hey, just as the title says.....I've searched and didn't find anything so if you could give me some ideas as to what might be wrong or where to look for the answers that'd be great. It blows, but goes cold when I stop at a light.....as I'm driving it's as hot as can be assuming the engine temp. is up. thanks
Old Feb 10, 2006 | 11:31 AM
eric-the-red's Avatar
I would guess a partially clogged heater core, or a bad water pump. It looks like you're not getting enough coolant flow through the heater at lower engine speeds.
Old Feb 10, 2006 | 12:13 PM
Quakefire's Avatar
Check your coolant level, when coolant is low the heat will quit working at low rpm
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
jerusry
Oct 19, 2015 05:28 PM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
