22RE In 92 PICKUP??
Old Feb 8, 2006 | 07:12 PM
awoods's Avatar
22RE In 92 PICKUP??
Hey all,
Im thinkin bout buying this 92 toyota pickup 4cyl 5-spd deluxe ext. cab pickup. I have done some searching but am still confused about the 22re, and the 22r engines and what year/model they came in... Does this particular truck have a 22re.. i heard that only automatics have them?? is that true?? any help would be greatly appreicated...
thanks so much
Old Feb 8, 2006 | 07:28 PM
Joyota's Avatar
You definately have a 22RE.
http://www.4x4wire.com/toyota/faq/parts/
Old Feb 8, 2006 | 07:30 PM
awoods's Avatar
awesome thanks...
it has 160,00 miles... no rust... looks clean im thinking about calling the guy tomorrow...new tires...ext. cab, deluxe... hes asking 3500 or best offer... good deal??
Old Feb 8, 2006 | 08:01 PM
trythis's Avatar
i paid 4200 for an 89 with an automatic and the 22re and I am happy, take it to a mechanic for a once over and pay the man if it passes within reason. I assume it's a 4x4, if not, the price is still good. SR5?
Old Feb 8, 2006 | 08:10 PM
awoods's Avatar
yes it is a 4x4! thanks for the help guys.. im just a lil excited... now i need to figure out what im gonna do with my 4runner?? hmm.... i can think about that later... i wish i could sell it before i bought this but not sure i have enough time.. i will definately take it to a mechanic... thanks so much!
Old Feb 8, 2006 | 08:14 PM
FOCUSHERE's Avatar
i bout a 92 22re with lil surface rust with 99k for 2000
Old Feb 9, 2006 | 05:33 AM
PirateFins's Avatar
see my sig they definitely have a 22re and 5spd
Old Feb 9, 2006 | 08:18 PM
kyle_22r's Avatar
22R and 22R-E are exactly the same engine mechanically. the difference lies in the induction -- the 22R is carbureted, while the 22R-E has multiport fuel injection.
Old Feb 10, 2006 | 08:53 AM
maxpower_hd's Avatar
The EFI 22RE was used in trucks beginning in 1985. It uses the same crank and rods as a pre-1985 22R but has dome top pistons, a taller deck height on the block and a shorter deck height on the head. As a result, the oil pump, timing cover and timing set are also different.
There was an EFI 22RE made from 83-84 that was used in Celicas. That one has an identical lower end as the 22R with a different head.
Unfortunately, I found all this out the hard way. I ended up with a 83-84 22RE that I can't really use.
Old Feb 10, 2006 | 05:48 PM
84sr5yoty's Avatar
And 84 2wd SR5 pickups. I have one
Old Feb 11, 2006 | 07:56 AM
surf4runner's Avatar
mine has a 22re. sticker on the valve cover says so
MO transplant
Apr 23, 2023 11:58 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
