Leak in oil pan. Info needed
Guys, I just got home and noticed a slow pool of oil(slow drip)coming from under the runner. Took a look and its my oil pan.
Do i need to remove anything,, like maybe the front axle to get this off and a new one in or just tie rods?
Any way to repair the existing pan?
Thanks lads.
Dwayne
Thanks lads.
Dwayne
Whereever oil leaks from, it eventually makes its way to the bottom of the engine and falls off the pan. In other words, every oil leak, from the main seal up to the valve covers, "looks" like its coming from the pan.
So before you start banging on the pan, I would get the engine clean enough to eat from (use the "water soluble" spray engine cleaner, but don't go nuts). Then look for the leak; you might be surprised.
I believe that on the 4wd trucks you must a) remove the front differential and axle or b) remove the engine, in order to remove the pan (this is true on the second-gen trucks). It's a big job, and you want to be sure you're fixing the right thing.
Good luck, and keep us posted.
PS I assume there's a lot of "rust colored" dirt where you drive. If not, the rust may be all that's holding the pan to the engine ....
the 93 fsm is pretty much the same
https://www.yotatech.com/forums/f116...umbers-102344/
you will have to drop the front axle to get the oil pan off
and like noted above clean off the motor real well before you remove the oil pan it could be leaking from some where else
I have found whatever degreaser you use it is best to rinse it off with hot water I run a garden hose from the washing machine or kitchen faucet and it works wonders.
Thanks for the info boys. Yep, it's good ol Island soil thats covering the bottom of the truck. I'll clean her up see whats going on with the leak and will let you know.
Thanks again.
Dwayne
Thanks again.
Dwayne
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
WI Girl
Jun 25, 2015 03:45 AM
newzingo
Jun 19, 2015 04:37 PM
