whats the difference?
Old Aug 28, 2008 | 09:28 PM
mammoth85runner's Avatar
i have a 85 4runner with an 88 motor/tranny. I also have an 86 turbo pickup. I want to evntually swap the turbo motor, harness, ecu, etc. but whats the difference batween the w56 and the turbo tranny? will my 88 fuel injection work? the turbos injection is toast....please help
Old Aug 28, 2008 | 09:38 PM
abecedarian's Avatar
turbo is different than non-turbo
what else?
Old Aug 29, 2008 | 08:24 AM
yes, i understand, there are small differrences between the turbo, and non. I want to use the w56 because it is much more solid or should i use the turbo tranny? i heard the turbo trans is heavier duty. will the w56 hold up?
Old Aug 29, 2008 | 08:48 AM
saitotiktmdog's Avatar
That statement doesn't really make sense. But anyways I believe that the turbo tranny is similar to the v6 tranny. I am pretty sure that the clutch is different. Heavier duty. Anyone know for sure and can correct me.
Old Aug 29, 2008 | 09:40 AM
DeathCougar's Avatar
Turbo trans will bolt up to the non-turbo engine no problem. The turbo trans is better than the non turbo, mainly because of the 23 spline t-case shaft and the lower 1st gear ratio.
LotOMiles
Sep 14, 2015 11:45 PM
EatChipsNow
Sep 9, 2015 01:25 AM
Jwp1
Sep 6, 2015 11:03 AM
justdifferentials
Sep 5, 2015 06:52 PM
LJR
Sep 5, 2015 06:02 AM
