whats the difference?
i have a 85 4runner with an 88 motor/tranny. I also have an 86 turbo pickup. I want to evntually swap the turbo motor, harness, ecu, etc. but whats the difference batween the w56 and the turbo tranny? will my 88 fuel injection work? the turbos injection is toast....please help:banger:
turbo is different than non-turbo
what else? |
yes, i understand, there are small differrences between the turbo, and non. I want to use the w56 because it is much more solid or should i use the turbo tranny? i heard the turbo trans is heavier duty. will the w56 hold up?:great:
Originally Posted by mammoth85runner
(Post 50909926)
Turbo trans will bolt up to the non-turbo engine no problem. The turbo trans is better than the non turbo, mainly because of the 23 spline t-case shaft and the lower 1st gear ratio.
