95 truck bed won't separate from frame
Old Aug 29, 2008 | 06:46 PM
GenXr's Avatar
I've unbolted the bed in 8 places, unbolted the fuel filler from the body, removed the tow hitch and bumper but I can not get the bed to budge one bit away from the frame.
Is this common? Does any one have good advice?
Two things I tried, my buddy and I got on each side and tried to pull it up, and the other thing was I put a 2x4 on one of the trusses and tried to jack it up slowly with a floor jack. Neither technique worked.
What else have I forgotten? (I know I need to disconnect the wiring before removing the bed)
Old Aug 29, 2008 | 07:07 PM
JamesD's Avatar
Does this truck have body lift on it?
James
Old Aug 29, 2008 | 07:22 PM
GenXr's Avatar
No, my truck currently does not have a body lift.....although I would like a 4crawler 1" BL.
Old Aug 29, 2008 | 07:28 PM
slacker's Avatar
really .... there are only 8 bolts holding it down . fuel filler and wiring , whatever ..
unless the bed silencer pads have dissenegrated , and the bed has rusted to the frame .. it should come off ..
just keep liftin'
Old Aug 29, 2008 | 07:31 PM
scuba's Avatar
try just putting your jack on top of your tire and go up, the bed itself is pretty heavy so it might take a bit.
But thats the best solution i can think of
Good luck and
Old Aug 29, 2008 | 07:53 PM
calisurferdude2000's Avatar
Do you have access to a chain hoist? If you do use the tiedowns and some chain to yank it off. That's what I did with my 87.
Old Aug 29, 2008 | 09:18 PM
gte718p's Avatar
Get A Bigger Hammer
Old Aug 29, 2008 | 09:33 PM
4Crawler's Avatar
Yep, should be just the 8 bed mount bolts (4 on each side) to remove. Maybe just need to jack it up a bit higher. You need to take the weight of the bed off the frame and suspension and thus the whole back end of the truck will lift up. Could be some of the frame brackets have rusted to the bottom of the bed.
Old Aug 29, 2008 | 10:04 PM
dropzone's Avatar
Fossilized
spray some rust penetrator on the body/bed mounts and let it soak. If Ohio salts their roads like they did when I lived in NY it will take a little time soaking. Try also chaining the truck frame to the floor jack so that when you are lifting against the bed (use a 2x4 or something to spread the load across the bottom of the bed) it does not try to left the whole back side of the truck.
Old Aug 30, 2008 | 02:08 AM
kipres's Avatar
did you disconnect the gas tank tube?
Old Aug 30, 2008 | 05:23 AM
GenXr's Avatar
ok, great advice everyone. I'll try the different techniques this afternoon and report back on what worked.
Old Aug 30, 2008 | 05:00 PM
GenXr's Avatar
Success! It took a combination of more PB blaster between the mounts and using a crow bar to pound in between the bed and frame. It finally popped loose.
I've got a lot of work to do to clean up the frame. The main fuel line coming from the tank rusted and spewed fuel everywhere (the main reason I took the bed off).......and now I can't decide between one of Roger's 1" lift or a flat bed!
6th Gear
19
Dec 10, 2019 07:31 AM
4x4-runner
Feb 26, 2017 06:42 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
TheManOutside
Jun 18, 2015 03:32 PM
