Truck is skipping
Old Sep 2, 2014 | 05:22 PM
John86Yota's Avatar
Truck is skipping
I got a 1986 toyota pickup and it's got a bad skip to it. I've already changed the spark plugs twice now and also changed the fuel filter. Anybody got any suggestions what I should do next?
Old Sep 2, 2014 | 05:36 PM
Hugh_Mann's Avatar
Have you pulled the distributor cap and had a look in there? Check for spark at all your wires? Could also check the ignition coil.
Might be a long shot, but after working on my 22RE one night one of the injectors came unplugged. Always a chance!
Old Sep 2, 2014 | 11:27 PM
wyoming9's Avatar
Red face
Just curious you didn`t do Cap and Rotor and wires as well.
How long has it been missing ??
I have never seen a vehicle skip but one does see new things.
Old Sep 3, 2014 | 12:57 PM
John86Yota's Avatar
Thanks for the suggestions I'll try it. And also I got a rough idle to and it's ticking really bad but I think adjusting the vales might help. I'm just worried it might be time to rebuild the engine
Old Sep 3, 2014 | 12:58 PM
John86Yota's Avatar
And it's been missing sense Thursday.
Old Sep 3, 2014 | 01:12 PM
millball's Avatar
Well, maybe whoever took it will be able to get it to run better.
Old Sep 3, 2014 | 01:52 PM
wyoming9's Avatar
Red face
Cute!!
Old Sep 3, 2014 | 01:58 PM
John86Yota's Avatar
Haha the truck is not missing it's miss firing
Old Sep 4, 2014 | 04:44 AM
PapaChulos4U's Avatar
Ha, nice!
I would say check plugs, cap, rotor, timing, then if that doesn't work check fuel pressure. Does it smell like it's running lean or rich? Could also be the catalytic converter....
Old Sep 4, 2014 | 05:38 AM
Badger62811's Avatar
Is it ticking like valves or ticking like you have an electrical short/arc somewhere? I had a bad plug wire that was arcing. It also caused the same symptoms. Change your plug wires.
Old Sep 4, 2014 | 04:17 PM
John86Yota's Avatar
It's ticking like valves and it's running rich.
Old Sep 5, 2014 | 03:49 PM
jennygirl's Avatar
Sounds like an ignition issue, are you positive it's the valves?
Recently replaced my wires and they didn't make a full connection with the cap for some reason. I took a flathead and bent the little tabs on the wires (cap end) out about 1mm which gave them more grip on the cap. A slight bit of dielectric grease and no problems since.
Also check the firing order, make sure you haven't hooked up the wires out of order.
1-3-4-2
Old Sep 7, 2014 | 03:40 PM
John86Yota's Avatar
Thanks for the info I'm going to get new wires and plugs and the cap kit off lc engineering so hopefully that will fix the situation.
Old Sep 7, 2014 | 05:56 PM
If it's running rich then, yes, it's probably the wires/plugs not burning off the extra fuel.
Good luck!
Old Sep 14, 2014 | 01:03 PM
John86Yota's Avatar
So I changed everything runs somewhat better so now where going to cut the cat and muffler off cause it's clogged up and put a new muffler on. And thanks everyone for the help narrowing it down.
Old Sep 14, 2014 | 01:33 PM
jennygirl's Avatar
Thanks for the update!
Old Sep 14, 2014 | 03:06 PM
Duffdog's Avatar
Flat camshaft lobes also have been known to cause "skipping"
Old Sep 29, 2014 | 05:23 PM
John86Yota's Avatar
(Update on the situation) so we cut in front of the cat did not help the problem gave it some more power though. We did a compression test on it tonight and found out 3 out 4 have low pressure two of them have 40 and one 60. So I'm guessing it's time for a rebuild or new engine?
Old Aug 5, 2015 | 02:03 PM
yipyip45's Avatar
TPS! Just changed mine and it runs 10x's better
Old Aug 9, 2015 | 04:27 PM
superex87's Avatar
Either its blown a head gasket or you have a valve issue. Its rare for a engine to go from running good to running bad in a day and it be low compression due to wear and tear on the pistons/rings.
duckhead
170
Nov 13, 2017 06:07 AM
Ichneumon
Sep 27, 2015 04:21 PM
MadMax48
Jul 3, 2015 08:26 AM
ibayne
Jun 26, 2015 06:30 AM
