passenger side window does not work with master switch
Old Aug 17, 2014 | 05:29 PM
swerks's Avatar
I must start by saying I don't work well with electrical. my master switch will not work with passenger side window. I know the problem is where the wires pass through the driver side door, with the door open I can wiggle them and get the window to work. how hard is this to repair ? has anyone dealt with this? and how hard. I don't want to screw it up worse.
Old Aug 17, 2014 | 06:47 PM
scope103's Avatar
You've already done the hard part; you know almost exactly where the problem is. Now, it's just getting to it.
This post has pictures that might give you some ideas: https://www.yotatech.com/forums/f116...t-work-254772/
I'd use the manual to examine the driver's side switch to confirm the color of the wires you're worried about. http://personal.utulsa.edu/~nathan-b.../7powerwin.pdf My schematics show R-B and R-G from the driver's side switch over to the passenger side switch.
Old Aug 17, 2014 | 11:02 PM
wyoming9's Avatar
Red face
Might be easier to just get the harness that goes from the Master switch to where it plugs into the cab harness .
Since you admit to a lack of electrical skills so far.
If one wire is broken wont be long before another.
Just another option.
Old Aug 21, 2014 | 09:33 AM
swerks's Avatar
has any one opened the harness where it gos through the door and tried repairing the wires there ?
Old Aug 21, 2014 | 02:35 PM
wyoming9's Avatar
Red face
I have done these and back windows quite a few times .
I use a bare butt connector for a physical connection then solder and heat shrink.
It is much easier to remove the harness then try and repair in place.
That way you can also ring out the other wires as well as inspect.
gillesdetrail
Nov 19, 2019 12:56 PM
scottt80
Jul 1, 2015 12:13 PM
miceal383
Jun 29, 2015 12:27 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
