Is it possible to add power steering...
Old Aug 8, 2014 | 03:16 PM
djtroy's Avatar
Trying to find the parts to add power steering to my 1992 Pickup. Has anyone else done this?
Old Aug 8, 2014 | 04:24 PM
Rerunn's Avatar
You need the gear box, crank pulley and pump bracket with the pump. I plan to do the same except run the psc kit
Old Aug 8, 2014 | 05:13 PM
djtroy's Avatar
Does anyone sell the parts as a kit or do you know how I could get everything I need. What about mounting bracket? Is getting all the stuff from a junk yard the only option?
Old Aug 8, 2014 | 05:18 PM
Rerunn's Avatar
More than likely junkyard is your best bet
Old Aug 8, 2014 | 05:50 PM
Robert m's Avatar
Yes its possible. I did it on my truck last year. Took about 3-4 hours to get the old parts off and new parts installed and working. Buy new lines and hoses and make sure you use ATF for fluid and not power steering fluid.
Old Aug 10, 2014 | 04:19 PM
djtroy's Avatar
Do you have any tips on what year parts to get and was there anything that presented a challenge during install? What about the mounting braket?
Old Aug 10, 2014 | 09:45 PM
Robert m's Avatar
AFAIK the pump, brackets, crank pulley, and reservoir should be the same for all 22re's. The box, hoses, cooler line, and steering shaft might be different for each generation but I dont know for sure.
I got my box, crank pulley, and steering shaft from the junkyard and then the brackets and cooler line from someone parting out a truck. I got new hoses, idler pulley, belt, and pump from the parts store and I am running a custom reservoir.
edoyle12
11
Mar 20, 2017 02:26 AM
Ironmike4x4
Feb 3, 2016 11:13 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
delmert
Sep 30, 2015 04:34 PM
shisha1999
Sep 20, 2015 11:44 AM
