Replaced some parts and still can't get idle right.
Old 10-20-2010, 04:27 PM
Charlie9422RE's Avatar
I posted a post about this before but since then I've done so many things and nothing has helped.
My problem started out when I would step on the brakes and the engine would surge. Everywhere I looked everyone says to lower your idle (Which I think is kinda crazy that you would have to do that... I wouldn't think you would have to ever lower your idle if everything was working correct) But when I went to lower mine I noticed my screw was already down. My engine now surges all the time; even worse when I step on the brakes.
I checked everywhere for vacuum leaks, set the ignition timing, Cleaned the TB and idle valve, replaced the thermostat and coolant sensor, and just today I replaced the TPS. Nothing has helped it at all. I'm running out of ideas. I feel like maybe there is a vacuum leak somewhere. I just don't know where to look anymore. I have a code (the only code I have) for a TPS but I replaced that today and it didn't help at all.
Note: When I jump the data link it runs a lot smoother and doesn't surge.
If anyone can help it will really help me out a lot. My other car is being painted at the moment and I was counting on my truck for the next couple weeks.
Old 10-20-2010, 05:24 PM
TNRabbit's Avatar
This is a common problem with automatic transmission models. I don't know exactly what the fix is, but it's been covered a dozen or more times in the past. Perhaps someone else will be along shortly & address it more precisely...
Old 10-20-2010, 05:40 PM
iamsuperbleeder's Avatar
exactly what parts have you replaced, just the TPS?
Old 10-20-2010, 05:42 PM
Thanks for the reply. I actually have a Manual Trans. I know that a lot of people run into these issues and its all been covered so many times. I've spent hours searching , not just this forum but the whole internet. Im thinking about just getting rid of the truck.
Old 10-20-2010, 05:43 PM
I replaced the TPS, Thermostat, and Coolant sensor.
Yont283
09-23-2022 08:06 PM
subaruwrx88011
10-09-2015 12:39 PM
miceal383
06-29-2015 12:27 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Replaced some parts and still can't get idle right.
