87' 22RE 4x4 A/C VSV vacumm line question
Just picked up an 87 4runner yesterday and am going through the vacumm lines. I see there is one loose line hanging off of the AC VSV, Any idea where this should go?
Also any idea what this is?
according to this diagram it appears both lines go into "acutator" i didnt see a second nipple on the valve, but i will doublecheck
Check the backside of that white thing with the spring and slot on the top to the left of your hand in the first pic. That is the AC actuator and there is a small vacuum fitting on/under it.
The other pic is just a vacuum hose with a filter on it, it looks perfect the way it is.
