Power window probloem
Old Oct 29, 2010 | 05:14 PM
swerks's Avatar
Power window problem
When I use the power window switch for the passenger window, located on the drivers side master switch it only works intermitently. when i use the switch on the passenger door it works perfect. Any ideas ??? this is my 86 Turbo 4Runner.
Old Oct 29, 2010 | 06:12 PM
shaeff's Avatar
Take the switch out and clean it. Likely just built up gunk.
Old Oct 30, 2010 | 06:17 AM
swerks's Avatar
I have tried that even tried a second switch and it did the same thing.
Old Oct 30, 2010 | 07:50 PM
VABYRD's Avatar
make sure one of the leads isnt loose from the harness.
Old Oct 30, 2010 | 09:58 PM
Datsayota's Avatar
I've seen the wires break in side the harness from years and years of opening the driver's door. Pull the rubber insulator back and take a look, it's usually fairly obvious.
Old Oct 31, 2010 | 02:10 PM
shaeff's Avatar
Even if it's not obvious, it's an easy check with a DVOM.
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
