OME 2 inch kit advise help
Old Dec 2, 2007 | 06:55 PM
TOYNRND's Avatar
I am a body man not a suspension guru. I am posting this here also because the springs on my rig are just like the IFS rigs and i would like to rap this up tonight sorry for being post happy. so I am finally installing an all new bolt on Old Man Emu springs all around, on my 1985 Toyota 4 runner. ON the rear springs I have run into an issue with getting the fixed end pin into the hanger( hanger tab hole diameter is too small to slide the pin in; perfect for the seated part and the end of pin threads.). The pin fits nice in the spring eye bushes but that diameter is to big to slide through the hanger. the only way to get it in that i can come up with is to either file the hanger holes larger; which would leave a gap where the pin is suppsed to rest on the hanger tab;or bend the hanger tabs out then in and around the pin loaded spring end. whew. Hope this makes sense and i hope someone can help me. its probably something simple but the instructions dont address this issue. it seems like it should just slide in from the side but it wont fit. thanks for any help on this.
__________________
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
