the overzealous starter...
Old Dec 6, 2007 | 02:23 PM
gbalias's Avatar
im guessing its the ignition switch, but on my 88 p/u 4x4, every now and then (and it has been getting more frequent) when i go to crank the motor, the starter doesnt want to stop. i have to keep turning the key to the start, then off, then start, then off positiotns repeatedly until i get lucky that it stops.
has anyone else had this happen? would it be the ign switch?
Old Dec 6, 2007 | 03:08 PM
rowdy235's Avatar
could also be the starter solenoid sticking. Easy enough to take it apart and lube it. I think you use graphite lube.
Old Dec 6, 2007 | 05:49 PM
gbalias's Avatar
ah good point. didnt think of that. ill have to do some more investigating i guess.
Old Dec 6, 2007 | 11:40 PM
gbalias's Avatar
i think its on the starter side of things. i imagine if it was the relay or ign switch, when i let off the clutch, the circuit wouldnt be complete anymore.
instead, as it is now, i can turn the key all the way off, take it out and get out of the truck and the darn thing will still be turning over. makes for an interesting sight for bystanders. hahaha.
Old Dec 7, 2007 | 08:15 PM
gbalias's Avatar
ok...update.
removed my starter this morning, opened it up, and cleaned everything.
the solenoid was grimey and contacts were corroded. i cleaned, lubed and degunked the contacts. so far so good. it actually stops turning over when i turn off the ign switch!
Old Dec 8, 2007 | 06:09 AM
Ricer-X's Avatar
WOW
small world
how ya doin george?
Old Dec 8, 2007 | 07:26 AM
rowdy235's Avatar
glad to see things turned out good for ya
knock on wood
RSR
Mar 26, 2023 11:10 AM
SLAYfriknBODIES
Dec 1, 2014 05:53 AM
93toyopickupCT
Oct 12, 2012 12:16 PM
LOCOMOengineer
Feb 20, 2012 01:31 PM
justin graham
Sep 7, 2011 10:32 PM
