1987 yota 22r
Hey there. I have a 1987 toyota pickup 4x4 with a 22r. Would I be able to just get the re intake and some of the wiring and be able to have a running re on my stock 22r? Thanks
No it is not quite that easy!!
You would need the engine harness with sensors and the ECU
You would also need to upgrade the fuel system to the higher pressure needed for the injectors
If this is what you meant by getting the intake and fuel rail and some of the wiring .
Then it would be Yes
Staff
If you mean a full on conversion from a 22r to 22re that is a big No. You have to do a major tear down from one end of the truck to the other. I am currently doing one and will be doing some more later today. Here is what I have gotten done so far. https://www.yotatech.com/forums/f199...l#post52146627 and on to the following pages. I figure I am 40% done.
I will eventually make a thread doing it step by step, but even still there is alot of information that would take a book to write as of all of the differences in the wiring, injectors, and so forth. You have to swap tanks, fuel lines, gut the interior, it is a big job.
No it is not quite that easy!! You would need the engine harness with sensors and the ECU You would also need to upgrade the fuel system to the higher pressure needed for the injectors If this is what you meant by getting the intake and fuel rail and some of the wiring . Then it would be Yes
What kind of problems are you having with your carb? Is it stock? You might also want to look in to a weber carb conversion. If you can get them tuned right, you wont have to deal with most vacuum problems and any problems your stock carb might have. Jetting is key however.
It's lugging on me until I step on it. And my carb that is getting rebuilt was too rich and we couldn't get it to run right with it on. It just didn't want to run.
Dont narrow it straight down to the carb. You sure all cylinders are firing? Whether it be due to compression, spark or fuel? You could have a dead cylinder causing no bottom end power. have you checked the timing? Could also be a possibility. I would check timing with your buddies carb and make sure it's on point.
Hey guys I'm still waiting on my carb but it should be done soon. We ran a compression test today and it was around 175 in all 4 cylinders.
I'm still trying to figure out if I have the same head as a 22re.
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
Jcrawl94
10
10-24-2015 04:34 PM
