22re Compression Test - opinions?
Old Feb 23, 2014 | 10:01 AM
Ejams's Avatar
I have a 22re with 276k on it. The other day a hose spring a leak and it overheated. After repairing the leak and refilling it seemed to drive ok.
When I got home I changed the oil. No water mixing, not metal flakes. Flushed the cooling system. No oil in coolant. No smoke, coolant level is holding steady. So far it seems to drive and sound ok. I'm thinking I may have dodged a bullet.
Compression test results are as follows: #1 185, #2 170, #3 180, #4 150.
Adding some oil to #4 brought it up to 240. So it seems like maybe an issue with the #4 piston rings, but all in all not too bad considering the mileage on the motor.
Should I be especially concerned about #4 or just keep an eye on things over the next few weeks and recheck compression after a couple hundred miles? Thanks
Old Feb 23, 2014 | 10:11 AM
Inferno451's Avatar
I'd just keep an eye on it and be more careful next time. #4 does seem low, but if it's driving ok i'd just run it.
Old Feb 23, 2014 | 05:27 PM
SoCal4Running's Avatar
If it still runs ok which it probably does then I'd just keep on driving it.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
dumpster84
Apr 30, 2016 06:03 AM
RatOmeter
Oct 22, 2015 03:17 PM
A2theK
Jul 12, 2015 10:46 AM
