fuel guage incorrect
Old Jan 29, 2014 | 06:09 AM
sleeper bird's Avatar
Hello all i am new to the forums and did a search on this subject to no avail,i am somewhat unfamiliar with my truck as my father in law just gave it to me and never noticed an issue.Buti have noticed that the fuel guage when you fill up goes to full but after a few hundred miles is on empty.Upon checking the owners manual i discovered that it still has aprox 7to 8 gallons in the tank.I am thinking fuel sending unit,but i wanted to ask if this was common and could it be guage related?I have also noticed that the temp guage is unreliable at best, but saw the sticky to check that out.Its a 90 extended cab with a 22r fuel injected.
Old Jan 29, 2014 | 06:40 AM
CJM's Avatar
CJM
Thats the way they are. My T100 has at least 5-7 gallon left when it says empty.
Old Jan 29, 2014 | 07:22 AM
i have no problem with driving it on e but my wife kinda freaks out,guess theres always fresh fuel in there.When it hits dead empty it will only take 10 gallons of fuel to fill up.It just seems like your always having to stop for fuel.
Old Jan 30, 2014 | 06:19 AM
Terrys87's Avatar
The windings in the lever assembly is fine as hair. The wiper that moves up and down with fuel level will wear into the wire and break them. About the only way to fix it correctly is to replace the float assembly. I hear a Float Assembly runs around $100. Most likely is the cause of your problem.
For your Temp Guage, make sure the Ground by the fuse box inside the truck is making a good connection and here is a thread the might help>>> https://www.yotatech.com/forums/f116...ge-fix-271152/ Has helped quite a few others.
Old Jan 30, 2014 | 05:17 PM
I kinda assumed that was it,in the float part.Is it very hard to change?
Old Feb 2, 2014 | 12:21 PM
skeeter0288's Avatar
5 screws in top of tank and wire connections. hardest part in dropping tank. good luck getting one cheap.part discontinued and too my knowledge not made in aftermarket. change my sender and fuel guage with moeller marine sender and guage from amazon for 70.
wafoogalla
Nov 2, 2016 11:02 AM
RobotMoose
Sep 2, 2015 05:53 AM
AppalachianOffRoader
Aug 11, 2015 01:15 PM
JAmdor3
Aug 11, 2015 10:53 AM
shisha1999
Jul 13, 2015 11:09 PM
