high idle, cant turn down
Old Apr 1, 2010 | 08:17 AM
MTyoda's Avatar
My 1989 22re pickup is idling around 1200rpm and im told it should be at around 900. The bypass screw is all the way in and i dont know what else to do. any suggestions?
Old Apr 1, 2010 | 08:25 AM
GranVille-4crawler's Avatar
Vac leak. #1 culprit for high idle/ surge. Check all connections and then use soapy water to check for cracks or holes in lines
Old Apr 1, 2010 | 08:32 AM
Tubbyfatty's Avatar
Do 22re's have dashpots? My 3vz had a high idle and my dashpot wasnt allowing the throttle to return to normal. I just backed the screw off of it. Works fine now.
Old Apr 1, 2010 | 08:57 AM
abecedarian's Avatar
If you can't adjust the idle down using the TB screw, check that the o-ring around the screw is in good condition, check for vacuum leaks. Check that the throttle cable isn't holding the throttle open, check the idle air valve (under the throttle body) is working.
Old Apr 1, 2010 | 01:47 PM
metalhed's Avatar
dashpot- yes on a 22re they do exist
spray it with WD-40 and it might help
Old Apr 3, 2010 | 09:42 AM
MTyoda's Avatar
The idel only surges when i brake hard to slow down in neutral or with the clutch in, ive herd there is a sensor in the ecu that trips to cut the fuel if the idel is over 1100 when braking. so i think im clear on vacum leaks but i think it may be a bad tps. any thoughts?
Old Apr 3, 2010 | 01:34 PM
I know the my truck did that before I adj the idle, there is a vac line going to your brake booster that cuts fuel to your eng under braking to save gas. But I guess if you can't turn uour idle down you can't fix this
Old Apr 3, 2010 | 03:22 PM
myyota's Avatar
Get some carb cleaner and use it to check for vacuum leaks, check all the vacuum hoses, check the gasket between the throttle body and intake, also check the idle air control, sometimes they can go bad.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
ZONAYODA
Jul 13, 2015 07:17 PM
