throwout bearing replacement
Old Mar 27, 2010 | 12:15 PM
PirateMcgee's Avatar
on an 86 22re 5spd 4runner how do you replace the throwout bearing into the carrier i.e. how do you get the old one out and the new one in? A diagram would be great or pics if anyone has them...
thanks!
Old Mar 27, 2010 | 12:42 PM
Evil.Dingo's Avatar
The way I got mine out was using a grease gun to pack-it full of grease...that is; pump the grease through the hole so that it fills in the cavity behind the bearing. Then use a correct OD diameter wood dowl that matches the ID of the bearing. Tap the dowl into the hole and it should displace the bearing, thus popping it out. You might have to top off the cavity with grease one or two times before it comes fully out.
I new I took pics of this process for a reason...
I used a ball peen hammer and wacked it maybe 10 times before it popped. With the wood dowel, your not going to damage anything.
Old Mar 27, 2010 | 12:49 PM
that's the pilot bearing man lol thanks though
Old Mar 27, 2010 | 12:56 PM
Evil.Dingo's Avatar
lol.....doh...beer. my bad!
Old Mar 27, 2010 | 01:40 PM
oldblue94's Avatar
If I remember correctly there should be like a metal clip holding it there.
Old Mar 27, 2010 | 02:26 PM
no not how to unclip it from the fork............
the unit is out....
when you buy a clutch kit it comes with a bearing only, that bearing somehow fits inside the carrier/housing. How do you replace the bearing in that housing.
Old Mar 27, 2010 | 02:45 PM
yayfortrees's Avatar
Ooh, that is different. My clutch kit came with the throwout bearing assembly. I just swapped them out, super easy. Let me go look at my old one for clues. BRB...
Old Mar 27, 2010 | 02:52 PM
Looking at my old throwout bearing assembly, it doesn't look like you can swap out just the bearing. I would go back to the parts store and have them give you an assembly with the new bearing already in it. That's the way it should be in the first place.
Old Mar 27, 2010 | 03:02 PM
flyingbrass's Avatar
Marlin clutches come with only the bearing. I took mine to the shop. They charged $5 to press the old one off and the new one on. I thought it best to have it done using the right tools, which I don't have, instead of risking screwing up the bearing.
Here are some pics of how the clips fit back on (if yours has the same style): https://www.yotatech.com/51346097-post250.html
Old Mar 27, 2010 | 05:06 PM
that doesn't look like mine either............
I'll post up some pics in a few
Old Mar 27, 2010 | 07:18 PM
Note to self: DO NOT EVER buy a marlin clutch kit. I think that is ridiculous. Even the standard clutch kit that I bought (nothing premium about it) included the entire assembly, ready to go.
Old Mar 28, 2010 | 06:03 AM
this is an oem kit
Old Mar 28, 2010 | 07:53 AM
yoterr's Avatar
when i bought my clutch same deal, just the bearing and not the whole unit...not that big of a deal just bring it to any competent shop and they will do it for 10 15 bucks like brass said...i brought mine to a firestone shop...lol it was the closest one...i think i had a thread on it..if you feel like searching my name i bealive i had pics of it too....
Old Mar 28, 2010 | 07:58 AM
yoterr's Avatar
nvm i had no pics lol was just told to press it off
Old Aug 18, 2010 | 02:41 PM
MortonPhotographic's Avatar
I am going through this now. What I am finding as the that the 3.0 V6 clutch throwout bearing is different than the 22R/22RE clutch throwout bearing. Problem is my 1988 4runner SR5 with 22RE and 5 speed trans has what I am pretty sure is a 3.0 V6 throwout bearing. Now my problem is finding the parts to press into this new bearing.
I hate when people put thing together wrong.
Old Aug 18, 2010 | 04:16 PM
Blue Steel's Avatar
hahhaha i took a look at this thread and was like hahah thats the pilot bearing! i dont know why imposting this sorry. hahah but yeah thats def a pilot bearing up there great pictures though. getting the pilot was such a PITA for my 3VZE. holy ˟˟˟˟.
Old Aug 19, 2010 | 05:19 AM
meswoleshane's Avatar
When I rebuilt the engine in my 4runner just recently I had this problem too. I remember looking at the assembly in one hand and the bearing in the other thinking how is this supposed to work? I took the assembly apart and it looked like the bearings were different so I didn't try to swap them, I just put the old one back in because it wasn't it too bad of shape...
Old Mar 24, 2012 | 10:53 AM
2012MongolRally's Avatar
I am facing this same problem.....I will post pictures later, but I can't find a machine shop open now (b/c its saturday and rightfully so) to press out the old bearing. More so, I am fairly certain the old and new bearings are different. If anyone has pictures of a how-to-do this would be great
Old Mar 24, 2012 | 02:22 PM
It's actually a different piece all together. Oreily auto parts had both parts. One is for 86-88 and the other is for 89-? I had the parts guy pull both parts and one of them looked exactly like mine.
Old Mar 24, 2012 | 03:51 PM
slacker's Avatar
throwout bearing is "pressed" on to the hub ..
a vice and a little ingenuity is all you need !! pop it off and press the new one on ..
