3vze wont start after head job
Old 03-24-2010, 02:42 PM
osamabinkeifen's Avatar
i can get my engine to start after getting a head job on my 4runner....all it does is back fire out the exhaust when i spray starter fluid in the engine?????
i put some downey headers on it during this process and i dont have my oxygen sensor hooked up. does it need that to run? i was going to wait to hook it up till i got my exhaust connected to my cat?
any help would be grand! this is beginning to haunt me in my dreams! lol jk
Old 03-24-2010, 03:44 PM
Mr.Chumchal's Avatar
I'm pretty sure not having your o2 hooked up has somthing to do with this. At the least hook it up and zip tie it somewhere to get your car to a muffler shop or where ever.
Old 03-24-2010, 04:31 PM
budro's Avatar
backfiring while it is trying to start. I believe this happens when the spark goes off when the exhaust valve is open. (timing ) This happened to me after a HG job as well cause I accidentally turned the engine before I installed the rotor assembly. It sounds silly but things do happen. Also these engines are known for there timing belt slips after installation. So you can do what I did and tear it down to expose the cam sprocket marks and insure they both line up and that the timing marking is at "0" and that the rotor is facing the #1 in the cap.
Good luck
Old 03-24-2010, 04:47 PM
Good luck
man that would suck to have to drain the coolant again to take the top timing cover off.
the rotor still lines up when the crank is at tdc.... ill guess ill start withthe oxygen sensor
Old 03-26-2010, 12:28 PM
budro's Avatar
what's the verdict?
Old 03-26-2010, 01:15 PM
Blue_petersen77's Avatar
Head job haha
Old 03-26-2010, 01:28 PM
hilux1026's Avatar
More than likely you have the dizzy 180 or 90 degrees out. This would cause the symptons you are describing
Old 03-29-2010, 11:55 AM
WINNER!!!! god i feel stupid!
Old 03-29-2010, 02:21 PM
hilux1026's Avatar
Glad to help
Old 03-29-2010, 03:05 PM
Dumb question: what is the dizzy?
Old 03-29-2010, 04:03 PM
hilux1026's Avatar
Distributor...slang term for it
Old 03-29-2010, 04:04 PM
hilux1026's Avatar
oh and by the way there are no dumb questions as this is the way we all learn from posts on here
Old 03-29-2010, 07:33 PM
Fo shizzle! Thanks man
Old 05-14-2010, 02:27 PM
9four4runner's Avatar
ok i have the same problem it ran good with out the alt and fan housing hooked up purred now with everytihng hooked up it wont even wana start wat gives?
Old 05-14-2010, 02:44 PM
wd21_sr5's Avatar
^froze bearing in the alt or fan mount?
Old 05-14-2010, 03:41 PM
so how can i tell if the alt bearing went out?
Old 05-14-2010, 05:09 PM
i took off the belts took off, the top timming cover, realined the marks up to tdc and dizzy at #1 but the alt is warm and magnitic for some reson that i dont konw
i need help
and still wont fire
Old 06-06-2010, 05:08 PM
sjlrunner's Avatar
I have the same problem? Did you fix it? I just did the hg's and it turns but no spark.
help?
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 3vze wont start after head job
