Tranny sound...
Old Mar 23, 2010 | 10:56 AM
poynter's Avatar
Tranny sound...
I can hear this sound like a metallic object bouncing around on a spinning shaft that sounds like it is coming from the tranny. It goes away when I press the clutch in. It sounds similar to something dangling on a driveshaft somewhat like a bell...
Ive looked under there and nothing is loose so I think it is inside.
Anyone have any suggestions? I think it has been this way for a while as I have heard it randomly before but it very apparent now that I have been riding around with the windows down. Clutch doesnt slip gears are all fine.
I also hear what sounds like fluid going though valves(like a shock) when I change gears, especially on a downshift but that might be normal.
I guess my first action will be to change the gear oil in the tranny.
Old Mar 23, 2010 | 05:53 PM
Flash319's Avatar
Sounds like your throw out bearing may be failing. You will have to pull the trans to know for sure, or just drive until it dies.
Old Apr 1, 2010 | 09:53 AM
poynter's Avatar
If the throw out bearing fails on me then Im stranded correct? Stuck in whatever gear it was in?
Does the fluid level in the tranny have anything to do with the TO bearing?
I may add some to see if it quits it down a bit.
Old Apr 1, 2010 | 10:18 AM
Flash319's Avatar
The throw out is what engages/disengages the clutch. If it seizes it will start to burn the fingers off the clutch. If it blows apart you will have no clutch, stuck in gear.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
