replacing PCV valve- shoudl i replace the grommet too?
Old Apr 1, 2010 | 07:04 AM
516593812's Avatar
I want to do it right, already have a new FRAM PCV valve for my '90 22RE. Do I have to replace the grommet if it's in decent shape/ if it doesn't break in the process? Is there any benefit to replacing the grommet anyway?
Old Apr 1, 2010 | 07:16 AM
GranVille-4crawler's Avatar
If its dry rotted and cracked looking id say sure why not. If not don't bother. I just threw a new pcv on mine and didn't touch the grommet no problems
Old Apr 1, 2010 | 07:28 AM
4Crawler's Avatar
I've found my old grommet was pretty hard and brittle, so it is good to replace it. Also makes installing the new PCV a lot easier with the new soft grommet.
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/25.html
Old Apr 1, 2010 | 07:55 AM
abecedarian's Avatar
The grommet is cheap so replace it.
Would you install a new engine without replacing the spark plugs?
Old Apr 1, 2010 | 08:33 AM
Tubbyfatty's Avatar
Make sure you put oil or some other kind of lube on the grommet when installing it. It helps alot lol.
Old Apr 1, 2010 | 09:34 PM
Jay351's Avatar
Haha, have fun! It took me prying both hands while holding the vc with my feet for 10 mins to pry that sob out.
Old Apr 3, 2010 | 11:39 AM
rustypigeon's Avatar
I replaced mine recently. It was brittle and had a very loose fit to the PCV valve. I am sure air was leaking through it.
Old Apr 5, 2010 | 07:56 AM
516593812's Avatar
i just replaced the PCV, it popped out with a bit ove leverage, the grommet looked fine & was still soft, popped the new PCV in. it runs a bit smoother now. the old PCV was charred/ oil crusted/ black
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
Jnkml
Jul 6, 2015 01:20 PM
