Catalytic Converter Theft - BEWARE!
So i was driving to work this morning and when i pulled out onto the highway i got on the gas pretty hard and when i shifted into fourth gear i heard a pop then it sounded like my exhaust fell off!
I pulled off to see what was going on and i didn't notice a break in the exhaust or anything. I drove it like it was to work and took a better look at it when i had time. I found that someone had removed the bolts and sensor on top of the catalytic converter. I must have created enough pressure when i got on it this morning to blow the sensor out of the hole (which someone removed the bolts). I looked a little more and realized that the bolt heads were stripped like somone was trying to take the entire cat off. So i came to the conclusion that someone tried to steal it. This has been happening alot around where I live because scrap yards pay so much for catalytic converters. I found this on wikipedia and i figured you might wanna take a look at it:
Catalytic converter theft
Due to the use of valuable precious metals including platinum, palladium, and rhodium, catalytic converters are a target for thieves. The problem is especially common among late-model Toyota trucks and SUVs, due to their high ground clearance and easily-removed bolt-on catalytic converters. Welded-in converters are also at risk of theft from SUVs and trucks, as they can be easily removed with a battery powered reciprocating saw.[2]
So beware on where you park your trucks guys!
I pulled off to see what was going on and i didn't notice a break in the exhaust or anything. I drove it like it was to work and took a better look at it when i had time. I found that someone had removed the bolts and sensor on top of the catalytic converter. I must have created enough pressure when i got on it this morning to blow the sensor out of the hole (which someone removed the bolts). I looked a little more and realized that the bolt heads were stripped like somone was trying to take the entire cat off. So i came to the conclusion that someone tried to steal it. This has been happening alot around where I live because scrap yards pay so much for catalytic converters. I found this on wikipedia and i figured you might wanna take a look at it: Catalytic converter theft
worthless dregs of society!! stealing Catalytic converters... Geezz.....
sorry for the rant but come on thats just ridiculous... it happens here all the time too.. my friend has a muffler shop and he's had a lot more lately coming in...
Damn tweakers!!! get off the meth!!!!
/rant!!!
Most of them around here just get cut off. I guess a lot of armor plating might help. Maybe some kind of fancy alarm system, you know....the type that beep when someone just gets close to your rig, combined with a pager alert system and a 12 gauge loaded with 00buck.
So with all the posts on this lately and after reading this article:
Newsweek Article on rising Catalytic Converter Thefts
I thought I'd post up more info: - In the article they mention a shop in Akron Ohio that has developed a cage:
"An Akron, Ohio, welding shop hasn't waited. American Welding now sells a steel cage called a "Catclamp," a device for cars and trucks that encases the converter, which was first developed last year for rental trucks, says the company's James Dusa. "The phone is ringing off the hook," says Dusa. "
http://catclamp.com/catclamp.asp
I've emailed them to ask about pricing - and discounts for larger buys...
Haven't heard anything yet...
I wonder just how hard aircraft cable is to cut, I can't image it being any harder to cut than a bicycle locking cable and I think those just require some big bolt cutters don't they? But it may just be enough to get the lazy slimeball to look for another easier cat to steal. Our trucks have pretty easy access with 2+ feet of working space though. I like the one link that mentioned buying a low rider LOL, like crooks can't use a jack.
My cat isn't worth nearly as much in recycle value as the stock cats are. I got $140 cash for my old 93 cat and my smaller cheaper replacement was only about $60 new off ebay.
Yeah my old cat was very hard to see though compared to the new one. You don't have to wait for someone to steal it though LOL. With the recycle valve far exceeding the replacement valve it almost pays for itself to switch it out.
Well, the other day I found my O2 sensor hanging from the wire, completely unbolted from the down tube into the cat. (not on the cat itself). The studs were fine but the nuts long gone. Apparently the gasket had blown, giving the nuts enough wiggle room to come off and blow the sensor off. Apparently this is not so uncommon, from what my parts guy said...
The nice thing is that this was made with cable and if you were out to steal cats you would probably bring a wrench and a battery power sawsall, but i doubt many would bring along a big pair of bolt cutters.
Only down side is you might wake up to find all your windows broken out or a big gash in the side of your car out of anger.
That was the whole point of the article. Many scrap yards just "look the other way". Legislation in many states is trying to make scrap yards adhear to the same rules as Pawn shops. That would seriously limit the theives ability to get quick cash, and thuis would probably curb a majority of the meth heads from doing a quick steal.
Yeah, bicycle and cable locks are VERY easy to cut with a big bolt cutter. But if you have ever tried to cut cable with a saws-all... it sucks. The blade needs something that won't move and unles the cable is REALLY tight it will take forever to get through and be a big pain in the but...
because each one contains a few grams of platinum, which has skyrocketed in price from $500 an ounce in 2000 to more than $1,500 today
