egr removal
Old Jan 16, 2008 | 08:40 PM
cweich's Avatar
egr removal
If I remove my EGR valve, is there anything I need to do to the the computer it is still working?? 1988 22RE with a manual. The only reason I am removing it is in the way, not the valve its self, but the plate on the back of the head, I need that other half in for a project I am trying.
Old Jan 16, 2008 | 08:50 PM
Elvota's Avatar
I don't believe the computer will care... but it might effect your emissions if you need to pass that for licensing in your area.
Old Jan 16, 2008 | 09:04 PM
thook's Avatar
Watch the O2 sensor, also. It's going to throw the exhaust mix off a bit.....in relation to what the ECM is programmed for, anyway.
If yours doesn't have an EGR temp sensor, there's nothing there to "trick" in the way of the electrics. On the 3vze, with the temp sensor, one uses a little resistor. I'm sure the same for the 22re. I forget the specs on that in this moment. It's in numerous other threads, though.
Old Jan 17, 2008 | 05:18 AM
cweich's Avatar
No emissions to to worry about. Sounds good, Thanks
Old Jan 17, 2008 | 08:20 AM
LS1Steve's Avatar
it will run fine but you will have a check engine light. throw a 10k resistor across the egr connector on the end that goes to the computer and that will simulate a working egr and take care of the light
Old Jan 17, 2008 | 10:35 AM
TNRabbit's Avatar
You can pick up a pack of 4 of these resistors @ Rat Shack for next to nothing.
Old Jan 17, 2008 | 12:40 PM
nate V's Avatar
What kind of project are you trying to do???
Blamalam
Mar 12, 2022 07:34 AM
Colington
Aug 13, 2015 02:21 PM
e_richard
Jul 30, 2015 06:50 PM
montanatruck
Jul 25, 2015 03:45 AM
Snort
Jul 9, 2015 03:58 PM
