Alternator or Battery?
Old Jan 17, 2008 | 05:12 PM
Allstar93088's Avatar
Alright guys heres the deal, I just got my Pro Comp Lights both are 130watts. There not going on till i get my prerunner bar in so i been thinkin alot lately but i am kinda confused on an issue. I dont plan on running the lights all the time i just want to use then we i need them. Also other than the lights i plan on putting a system in my truck, probably two tens or whatever. I have read around alot and havent really come to any conclusion.
My Question is: Will the stock 22re alternator be able to keep up with the amps or wattage that i need to run my lights and the system? Would i be better off get a high output alternator or would a deep cycle battery do the trick for me?
Old Jan 17, 2008 | 05:16 PM
trd90toyota's Avatar
I ran a set up like that. Makes sure that you use a 40 amp relay. To be safe I'd would run a Red or Yellow top Opitma.
Old Jan 17, 2008 | 05:44 PM
SEAIRESCUE's Avatar
The two additional lights is over 20 Amps additional draw. Don't know your trucks alternator output and don't know how many amps are drawn with all the lights are on. If the battery dies, suspect more drawn than charged. Best wire them to the battery directly with a fuse or relay and big wire. Wire it to anything else and it will probably turn your wiring into a fusable link with meltdown impending. Bigger battery will not help if the alternator can not keep up with the demand and deep cycle is for trolling motors.
$0.02
Old Jan 17, 2008 | 05:47 PM
TNRabbit's Avatar
You're going to need an alternator upgrade.
Old Jan 17, 2008 | 06:16 PM
Thats what I feared...high output alternators can be expensive! Any bargain ones out there?
Old Jan 17, 2008 | 06:37 PM
TNRabbit's Avatar
Boyle Future Technology. Do a search on here for them. I had my Denso upgraded to 60 amps at idle, 130 amps max, for @ $170 shipped both ways from the east coast (they are in California). You want the highest amps at idle you can get. Forget about claims of higher amps; they suck until you hit max rpms. My alt. came back looking BRAND NEW!
Old Jan 18, 2008 | 04:55 AM
Does anyone know what the stock alternator (amps) puts out?
Old Jan 18, 2008 | 07:07 AM
TNRabbit's Avatar
60 amps total
Old Jan 18, 2008 | 08:26 AM
Thats max right? What about at idle?
Another Question: So an Optima battery wont help out my situation none with out having to rebuild my alternator?
Old Jan 19, 2008 | 09:26 PM
notanymore's Avatar
how powerful of subs were you thinking? but that is pushing the limit of the stock alternator. optima batteries are a waste of money unless you need the whole sealed jell thing, walmart batteries power your truck just the same as optima batteries, your best bet is upgrading your alternator so you dont have to worry if you are drawing too much power or not and you will have room to upgrade to more lights/bigger system or whatever down the road.
Old Jan 20, 2008 | 06:56 AM
As far as subs I plan on running a new brand of truck subwoofers called ALMANI. Went to my local stero place, long time customer and he always hooks me up with the latest stuff...he swore by these subs, I believe there 800W max and 400rms, I plan on running two. I am not sure what size amp yet. I am purdy sure I will be upgrading the alternator now, you guys make decision alot easier lettme tell you. Glad I found YOTATECH I would be lost with out you guys!
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
bradahman
Oct 1, 2015 09:24 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
