89 4 Runner motor swap
Old Jan 12, 2014 | 01:15 AM
BRMkane's Avatar
Going to do a motor swap the 3.0 for the 22re. Does it fit right in or do I have to make adjustments advice and tools I made need is greatly appreciated
Old Jan 12, 2014 | 01:25 AM
85toy4runner's Avatar
its alot easier to go with the 3.4 5VZ-FE its a direct swap but need some wiring done . 22re are great , but its not a direct fit you need to relocate engine mounts , bell housing will not bolt up to it .. etc
Old Jan 12, 2014 | 01:27 AM
wyoming9's Avatar
Red face
Do some research first!!
Please explain just why you would want to do this engine swap no less then 1000 words and please use references to support how you reached your decision.
BRMkane's Avatar
Is that a good motor? Idk to much about 3.4s all my friends have 22r or re
Old Jan 12, 2014 | 01:29 AM
BRMkane's Avatar
Originally Posted by wyoming9
Do some research first!! Please explain just why you would want to do this engine swap no less then 1000 words and please use references to support how you reached your decision.
What does it matter why? This is part of my research is asking advice from people who have already done it. If you don't have productive information than don't respond
Old Jan 12, 2014 | 05:42 AM
HighLux's Avatar
You are asking the most basic of questions....that if any effort was put forth whatsoever to search...you would not be asking.
Tip #1 use google to search yotatech. in google search box....add "yotatech" to the search. for example. "3.0 to 22re swap yotatech"
Search. Learn. Enjoy.
Play nice.
Old Jan 12, 2014 | 08:38 AM
BRMkane's Avatar
I'm trying to find out people's advice this is my research should I go 22re or 3.4 stuff like this I want to know so I know how to spend my money
Old Jan 12, 2014 | 09:19 AM
BigBluePile's Avatar
Going from 3.0 to a 22r-e is backasswards.
It's like wiping before you poop.
The entire drivetrain will have to be replaced. Any "research" would have lead you to that.
But yes. You could do it. You'll need new motor mounts, different transmission, tcase.....ext.
A 3.4 WILL BOLT IN SWAP IN PLACE OF A 3.0. Just need some wiring.
Old Jan 12, 2014 | 09:22 AM
buickid's Avatar
3.4 swap will require less mechanical work (as noted above), be a newer engine, more power, etc. Seems like a no brainer if you're going to be doing an engine swap.
Old Jan 12, 2014 | 09:23 AM
BRMkane's Avatar
What is the wiring needed
Old Jan 12, 2014 | 10:12 AM
JasonYota's Avatar
As said above please search. There is so much info on the 3.4 swap it makes it silly. Even the wiring part.
Old Jan 12, 2014 | 10:13 AM
BRMkane's Avatar
Do you have a link or something there are like 10,000 pages of 3.4 info I want the best one
Old Jan 12, 2014 | 10:21 AM
JasonYota's Avatar
Start with the stickies in the 3.4 swap section. Then read build threads that have your similar vehicle.
Old Jan 12, 2014 | 10:23 AM
BRMkane's Avatar
Okay I will thank you
Team420
Jan 12, 2021 04:57 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
infinityisfive
Jun 16, 2015 06:51 PM
