Broken Temp Sender?
Old Jan 11, 2014 | 01:45 PM
pascoscout's Avatar
Broken Temp Sender?
My temp gauge in my 1988 4runner (3.0V6, SR5) started acting up.
It was working ok, seemed like it always sat at 1/2 way after just a few mins of driving. I had to replace the speedo cable so while I had it out I thought I'd check out the wires on the temp gauge (as done in definitive temp gauge fix sticky). Didnt find any broken wires but did see some corrosion starting and a small glob of solder on the copper wires themselves. Cleaned off the corrosion and removed the solder (seemed like it didn't belong thought it was just a drip from assembly).
Now when I start the truck it reads cold like it should. But after only 1 mile (maybe 1-2 mins) of driving it goes from cold all the way up to the bottom of the red zone. Never goes higher than that. If I pull the plug off at the sender it drops back down to the bottom. I checked the engine temp with my infared tester and am seeing 180-190 at the block and T-stat housing so don't think its acutally running hot. The upper rad house and radiator are 170ish.
Could the sender be bad or did I screw up by removing that tiny drip of solder?
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
bradahman
Oct 1, 2015 09:24 AM
Brodetski
Sep 30, 2015 11:50 PM
rmill05
Sep 27, 2015 01:43 PM
