Limited Slip Question
Old Nov 24, 2007 | 06:35 PM
longhungsilver's Avatar
Hey guys I dont wheel a lot so dont make fun of me just had a diff question. WHen i bought my runner about 10 months ago the PO said it had a Detroit trutrac diff. I figured it was similar to a limited slip.. Sure enough both rear tires spin the same direction when i have the rear jacked up...but i can grab one tire (and stop it from moving) while spinning the other tire.. to me this means its not limited slip or perhaps the clutches are worn out?? if i burn out in gravel it leaves 2 tire tracks..
So am i just wrong in what a detroit trutrack is? or are my clutches worn out??
thanks guys
Old Nov 24, 2007 | 08:35 PM
loudboy's Avatar
google it
At first I didnt have an answer for ya, but then i tried a....
...GOOGLE SEARCH!
im new around here too, but simple questions can be answered easy enough by some quick research instead of pluggin up the forums
it is a limited slip, btw
Old Nov 24, 2007 | 09:04 PM
Jake97T's Avatar
No clutches in the trutrac, just pinions, nothing to wear out, its not a locker so one can be stopped and the other spins...
Old Nov 24, 2007 | 09:12 PM
4Crawler's Avatar
Sounds like a normal TrueTrac (a torque sensing limited slip diff):
- http://www.4crawler.com/4x4/TrueTrac.shtml
And you can lock them up with the brake biasing technique.
Old Nov 24, 2007 | 09:43 PM
Ganoid's Avatar
jack it up and pull the E brake while the tires are spinning to load it down.... then try stopping a tire while it spins . I use the E brake trick all the time on my TruTrac in fact its never let me down so I don't see any need to replace it with a full Detroit..
Old Nov 25, 2007 | 08:28 AM
thats a good idea man ill give that a try.
thanks for the responses guys
DeathCougar
Apr 1, 2018 11:29 PM
crammit442
7
Nov 29, 2017 12:30 PM
Ironmike4x4
Feb 3, 2016 11:13 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Cplmike
Jul 8, 2015 08:47 PM
