87 4runner brake booster
Old Nov 14, 2022 | 05:55 PM
Creepy crawler94's Avatar
Putting 1tons under my 87 4runner. What brake booster should I upgrade to that will bolt right up or work!!? Thanks
Old Nov 15, 2022 | 02:57 AM
PickleRick81's Avatar
The v6 brake booster from the 88 and up will give you much more brake power (bigger diaphragm) than the stock 1st gen 4 cylinder
You'll also want a bigger master cylinder to match that new booster. I have 4 piston v6 calipers up front and el dorado calipers in the back. This was too much fluid for the 1 inch bore 4 runner v6 or even fj80 land cruisers to handle, I had very squishy brakes
I used a sky 4x4 adapter to fit a Chevy 1 ton master to my upgraded Toyota booster. Now my brakes feel perfect for daily commute driving.
53-2776 is the booster part number
DougVa
2010+ 4Runner (Build-Up Section)
Aug 7, 2022 09:13 AM
dnbuggy
Feb 22, 2011 09:45 PM
truword1
Sep 13, 2010 06:34 PM
fishon1213
Jul 12, 2007 05:41 PM
