Sponsored by: CARiD
What is this? Brake booster connection
Old Feb 21, 2011 | 04:13 PM
dnbuggy's Avatar
What is the tube in the circled area for? It is located right below the carb. I just got an 87 suzuki samurai conversion with an 87 22r carburated motor and the engine ran like crap until I capped this port. It was just wide open. What is it for? Is it okay to just cap it or do I need it to do something else?
Old Feb 21, 2011 | 04:16 PM
xxxtreme22r's Avatar
old place where the toyota brake booster hose would go.
Old Feb 21, 2011 | 04:27 PM
peow130's Avatar
If the sammy has a brake booster vac line, run it to that port.
You might consider doing the toy MC swap into the sammy, if you're doing the toyota axle swap
Old Feb 21, 2011 | 05:04 PM
dnbuggy's Avatar
The sammy has toyota axles already and a Toy MC. Where exactly does this go? Straight to the MC? Is it bad if I just cap it?
Old Feb 21, 2011 | 05:06 PM
to a 1 way check valve and then to the booster. As long as your power brakes are working and your cap isn't leaking it's fine to cap that off.
Old Feb 22, 2011 | 09:45 PM
peow130's Avatar
Pics?
I'm a sucker for a built up sammy.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
corey519
Aug 12, 2015 11:12 AM
accuracy
Aug 4, 2015 08:05 PM
CanRunner
Jul 20, 2015 01:29 PM
87turboPA
Jul 12, 2015 07:49 AM
