Flame thrower injectors
Old Jun 11, 2016 | 11:33 AM
cbr600rx7's Avatar
I know this has been covered and reviewed a tone of times but my case is a little different and more of preventive maintenance vs upgrading. My rig currently has 240,000 miles on the clock and both valve cover gaskets are leaking. Since I am remove the intake manifold I am doing plugs, PCV, gaskets, and other related maintanace. I suspect my injectors are probably 21 years old and at thispoint they probably need to be replaced any way.
Old Jun 11, 2016 | 05:46 PM
ThorInc's Avatar
You can send them out to be cleaned, rebuilt and matched as well if your truck will be down for multiple days.
Old Jun 12, 2016 | 04:31 AM
cbr600rx7's Avatar
What's the cost of the flame thrower conversion vs having them cleaned and serviced.
Old Jun 12, 2016 | 06:02 AM
Turtl3's Avatar
Go with the flamethrowers for a little extra $, as opposed to cleaning and testing the factory injectors. Just put mine in the other day. Chances r that u will break all the electrical connectors for the injectors because theyre brittle due to heat and age. With the flamethrowers u get adaptors, so u can actually cable-tie the new plug to the old fragile loom between the 2 wires, giving a secure connection. And the new injectors have a spring clip design on the connection so theyre alot more hardy. Just an added bonus for the $ spent. This way theres no dramas with loose connections causing headaches down the road
Old Jun 12, 2016 | 07:22 AM
cbr600rx7's Avatar
That is what I am thinking. If I did send the stock injectors off there is also the chance one or two could be to far out of spec and then I'm out the cleaning and still have to buy more.
Have you been happy with yours?
Old Jun 12, 2016 | 01:05 PM
Turtl3's Avatar
Havent road tested the car yet, still waiting on a few other bits and pieces before i can. But im happy with the ease of plug and play, and that they work
Old Jun 12, 2016 | 06:51 PM
cbr600rx7's Avatar
So where can you buy them direct.
Old Jun 12, 2016 | 11:37 PM
Turtl3's Avatar
i contacted flamethrower and he sent me this link
http://www.ebay.com.au/itm/Toyota-4R...kAAOSwu1VW4jzi
Old Jun 13, 2016 | 08:28 AM
cbr600rx7's Avatar
What else should be replaced with the injectors and pig tails?
Old Jun 13, 2016 | 12:21 PM
cbr600rx7's Avatar
Referring to the injector cap and crush washer. I can't seem to find the part numbers.
Old Jun 13, 2016 | 03:36 PM
87hoerunner's Avatar
I've been running the flamethrower injectors going in two years now trouble free. Truck has more throttle response and fuel mileage is up 3.8% from my factory injectors
Old Jun 14, 2016 | 05:14 AM
Turtl3's Avatar
Flamethrower injectors come with everything u need apart from the copper washers for the fuel lines. I re-used mine no leaks.
Old Jun 14, 2016 | 06:55 AM
cbr600rx7's Avatar
They come with the little injector cups at the bottome of the injector?
Old Jun 14, 2016 | 12:00 PM
Yes they come complete ready to install
Old Jun 14, 2016 | 07:05 PM
Turtl3's Avatar
If ur referring to the large stepped cup that sits in the intake manifold, then no, it does not come with them.
ryancobryan
Jan 3, 2017 09:19 AM
Stuarrt
Apr 19, 2016 09:49 AM
87hoerunner
Mar 31, 2016 05:50 PM
Smaay
Mar 27, 2016 01:39 PM
Joshua White
Mar 19, 2016 03:17 PM
