Is it possible to install crossover with heads on?
Old May 17, 2016 | 02:28 PM
Austin148's Avatar
Has anyone done this? If so how?
Old May 17, 2016 | 03:24 PM
Austin148's Avatar
Anyone anyone? Bueller...
Old May 17, 2016 | 05:00 PM
Andy A's Avatar
Yes it is, but for the life of me cannot remember how. Last time I did head gaskets a couple of years back I ran into the same issue. Vaguely remember sliding it in somehow from the drivers side. Wish I could be of more help.
Cheers
Andy
Old May 17, 2016 | 06:00 PM
Austin148's Avatar
Originally Posted by Andy A
Yes it is, but for the life of me cannot remember how. Last time I did head gaskets a couple of years back I ran into the same issue. Vaguely remember sliding it in somehow from the drivers side. Wish I could be of more help. Cheers Andy
Andy-
I have heard of this! Do you remember if you had to remove exhaust manifold?
Thanks for the tip
-Austin
Old May 18, 2016 | 12:26 AM
Andy A's Avatar
Austin, sorry I do not recall on that, to old, to slow, and the memory just doesn't work like it use to. :-(
Cheers
Andy
Old May 18, 2016 | 07:08 AM
Austin148's Avatar
Austin, sorry I do not recall on that, to old, to slow, and the memory just doesn't work like it use to. :-( Cheers Andy
Thanks Andy don't worry about it. I appreciate the reply. This weekend I'll be tearing into and seeing if that method works. Take care.
-Austin
Old May 18, 2016 | 07:14 AM
scope103's Avatar
Hmmm. I'm pretty sure I was not able to get the cross-over OUT with the heads on, so I just disconnected it, and left it sitting there with the heads off. When the heads went back on, the cross-over was right there to connect.
(Which brings up the question: how did you get the cross-over out in the first place?)
So, having not actually tried it, I can't say for sure that you CAN'T install it with heads on. If you manage it, DO let us all know.
Old May 18, 2016 | 07:26 AM
Austin148's Avatar
Originally Posted by scope103
Hmmm. I'm pretty sure I was not able to get the cross-over OUT with the heads on, so I just disconnected it, and left it sitting there with the heads off. When the heads went back on, the cross-over was right there to connect. (Which brings up the question: how did you get the cross-over out in the first place?) So, having not actually tried it, I can't say for sure that you CAN'T install it with heads on. If you manage it, DO let us all know.
Hi! Thanks for the reply. I actually recently did a head gasket job and went through the whole engine and was planning on cutting the crossover for the "chief pipe mod" but when I did the exhaust shop said it would be way to close to the fuel line on the passenger side. So I ditched that idea but by that time the engine was basically back together. So now I'm forced to figure out how to get the crossover back on without taking heads back off.
Old May 18, 2016 | 07:45 AM
Trents3.slow's Avatar
Pull the heads or pull the engine. Something needs to move. That cross over pipe won't just slide in there. I'm not a Toyota expert at any means ,but I have some experience with the 3.0's.
Old May 18, 2016 | 09:20 AM
Austin148's Avatar
Do you have experience with rerouting the crossover on the passenger side?
Old May 18, 2016 | 09:48 AM
No I don't. I have always used the stock Toyota set up. When I did do a little research I found that an after market header set and down pipe was needed I think. It's not going to be CA or smog legal (I'm in California).
In my opinion. I wouldn't re-engineer the exhaust. Just get it back together and functional. OR drop a 3.4 in it if you want to get horse power gain and exhaust options.
Old May 18, 2016 | 04:48 PM
jgrant721's Avatar
I put Thorley headers on my '91 3.0 back in 2009 and definitely did not remove the heads to remove the crossover. I can't remember any particular drama getting it out but as others have said, time can dim the memory. I may have had to remove other bits to get it but definitely not the heads.
moroza
Mar 1, 2016 10:57 PM
vikecowboy
Mar 1, 2016 05:17 PM
HappyAdventure
Feb 20, 2016 06:32 PM
Rapidrob
Feb 19, 2016 10:35 PM
