Is it possible to install crossover with heads on?
Yes it is, but for the life of me cannot remember how. Last time I did head gaskets a couple of years back I ran into the same issue. Vaguely remember sliding it in somehow from the drivers side. Wish I could be of more help.
Cheers
Andy
Cheers
Andy
I have heard of this! Do you remember if you had to remove exhaust manifold?
Thanks for the tip
-Austin
Hmmm. I'm pretty sure I was not able to get the cross-over OUT with the heads on, so I just disconnected it, and left it sitting there with the heads off. When the heads went back on, the cross-over was right there to connect.
(Which brings up the question: how did you get the cross-over out in the first place?)
So, having not actually tried it, I can't say for sure that you CAN'T install it with heads on. If you manage it, DO let us all know.
Hmmm. I'm pretty sure I was not able to get the cross-over OUT with the heads on, so I just disconnected it, and left it sitting there with the heads off. When the heads went back on, the cross-over was right there to connect. (Which brings up the question: how did you get the cross-over out in the first place?) So, having not actually tried it, I can't say for sure that you CAN'T install it with heads on. If you manage it, DO let us all know.
In my opinion. I wouldn't re-engineer the exhaust. Just get it back together and functional. OR drop a 3.4 in it if you want to get horse power gain and exhaust options.
I put Thorley headers on my '91 3.0 back in 2009 and definitely did not remove the heads to remove the crossover. I can't remember any particular drama getting it out but as others have said, time can dim the memory. I may have had to remove other bits to get it but definitely not the heads.
FS[FourCorners]: 1992 Pickup 4X4 Manual - SLC, Utah
HappyAdventure
Feb 20, 2016 06:32 PM
