Possible newbie gear question
Old May 22, 2016 | 11:25 AM
TN Five-0's Avatar
In the process of deciding which gears I want for my rig. I'm thinking 5:29 just because I love low gears. My question is, can I use my stock third member that currently has 410 gears and replace the ring and pinion with the 529? Just covering my bases before I get this all done.
Old May 24, 2016 | 12:12 PM
az1320's Avatar
I was wondering the same thing. I am.looking at 35s and I was wondering if 5.29s where to small for a 4cyl and if the 3rd member would hold up or if there is like a nod-iron replacment.
Old May 24, 2016 | 12:19 PM
Billythekid's Avatar
You can reuse your current 3rd members and just re-gear them. The only one's you can't re-gear are the Toyota factory 4.88's. 5.29's are perfect for 35's. I have run 5.29's and 35's on many yota's, all with 4cyl.
Old May 24, 2016 | 03:41 PM
rattlewagon's Avatar
^x2
Youll need a new crush washer, which should come in a bearing/install kit. Or its a great time to switch to a solid pinion spacer. Tad harder to set up, but wont loosen over time. Good time to add a locker too, you know, while youre in there.
http://www.4x4wire.com/toyota/tech/crush_sleeve/
TG sells the solid spacers
Old May 27, 2016 | 12:25 PM
ZUK's Avatar
ZUK
Nitro or G2 Gear are the recommended brands. I have a couple links on how to install new 529 gears on my website.
Ken
Stuarrt
Apr 19, 2016 09:49 AM
87hoerunner
Mar 31, 2016 05:50 PM
daveybjr
Mar 26, 2016 04:28 PM
CARL0S714
Mar 12, 2016 06:32 AM
rondogracing
Feb 25, 2016 01:32 PM
