Welding near ECU question
Old Jun 10, 2016 | 04:19 PM
PreviousOwner's Avatar
It's time to cut out the passenger side rocker and weld in a new one. I intend to pull the ECU and disconnect the battery ground before firing up the MIG. Any other electronics I should be concerned about?
TIA
Old Jun 10, 2016 | 11:51 PM
wyoming9's Avatar
Negative cable disconnected you should be good to go.
You are removing the carpet and undercoating any wiring close to where you might be welding
I never did more then remove the negative cable on numerous vehicles .
A fire watcher is not a bad idea if it is practical
Old Jun 11, 2016 | 05:28 AM
Thanks for the reply. When I start it will be door off, seat out, carpet back, ECU removed and a welding blanket hung to block the interior...I hate doing something stupid that hurts my bank account. Now you've got me worried that Toyota may have run wires through the rocker. Thanks again, wyoming9.
Old Jun 11, 2016 | 09:26 AM
wyoming9's Avatar
If there are any wires they would under the carpet along the door
Why not just make Custom Sliders and forgo the Rocker panels ??
Old Jun 11, 2016 | 12:48 PM
The rocker is jammed up into the door; it still opens and closes, but it is catching water and transmitting the body vibrations to the window. If the old one has to come off, might as well put in the new one.
Custom Sliders is what should have happened a year ago.
Regency
Jun 9, 2016 06:54 PM
cbr600rx7
Jun 3, 2016 08:16 AM
AZ_98_4Runner
Jun 2, 2016 08:08 AM
KHoff
May 23, 2016 01:37 PM
jjrbus
May 12, 2016 11:10 AM
