87 4runner 3000 rpm
Old 05-17-2016, 06:11 PM
69SSRat's Avatar
87 4runner 3000 rpm
Guys im running 4 runner around 65 mph and 3000 rpm
the tires are 30.6 inch ,overdrive is working and reading its .71 so doing calculator it says rear axle is 540 or so just dont think this is right.
Old 05-18-2016, 02:07 AM
arlindsay1992's Avatar
What's your question?
Old 05-18-2016, 10:38 AM
RJR
RJR's Avatar
How are you measuring the mph? Your speedometer and tach know nothing about your tire size or rear-end ratio. They are calibrated assuming a certain tire size and gear ratio, which may or may not be what you currently have in your vehicle. Unless you've measured speed with a GPS or some other external method, you have no way of knowing how fast you are actually going.
Old 05-18-2016, 03:41 PM
highonpottery's Avatar
x2- what's your question???
~3k RPMs at 65mph sounds about right to me for a "stock ratio" of gearing to tire size.
Old 05-18-2016, 04:28 PM
osv
osv's Avatar
put the rear end on jackstands and count tire rotation vs. driveshaft rotation.
admiralnahohkta
03-01-2020 01:44 PM
tbryanh
06-08-2016 06:38 PM
TmbrWlf
03-01-2016 09:34 AM
nathanc
02-28-2016 05:58 PM
Quick Reply: 87 4runner 3000 rpm
