Heater Blowing COLD
Old Dec 7, 2005 | 01:34 PM
95Blue4Runner's Avatar
Heater Blowing COLD
it just froze over outside and i could careless except for the fact that i cant defrost my windshield
I have a 95 4runner
the heater is blowing cold air
and i drove it for about 45 min the other night on the highway and off and it still isnt blowing hot. Any suggestions on what i can do to fix this problem. Or should i just take it to the shop?
Old Dec 7, 2005 | 01:37 PM
snap-on's Avatar
got to move the little lever from the blue side over to the red side....
whats your antifreeze good for?
otherwise its I think there is a common problem with the linkage on the blue/red lever failing.
Old Dec 7, 2005 | 01:41 PM
that was a joke right?
is that something i could take apart and look at?
Old Dec 7, 2005 | 02:17 PM
ChickenLover's Avatar
Stick your head under the dash and look for disconnected linkage. I had this problem. Take a look at post #10 here . to see how I rigged it.
Old Dec 7, 2005 | 02:20 PM
tulsa_97SR5's Avatar
is your engine getting up to normal temp or running cold? Could be the thermostat stuck open.
Old Dec 7, 2005 | 02:49 PM
how can you tell
im not completely stupid when dealing with cars, but ive never dealt with the thermostat before
is this something i could fix myself if it is stuck open?
oh , and yes, i looked at the temp gauge and its running cold
Old Dec 7, 2005 | 02:55 PM
4x4Lamm's Avatar
Thermostat stuck open???
Fan clutch stuck???
Both???
Lamm
Old Dec 7, 2005 | 03:33 PM
leebee's Avatar
if the temp guage is showing it running cold, then the stat is probably stuck open. get a new one and install it, take a minute or two and check out www.4crawler.com . there are some good articles in there on heating issues.
lee
Old Dec 7, 2005 | 03:47 PM
Glenn's Avatar
Thermostat stuck open. The engine will eventually warm up even if the t-stat is stuck open.
Old Dec 7, 2005 | 03:55 PM
i shouldve taken care of this when it was 70 degrees outside
Old Dec 12, 2005 | 10:16 AM
someoneusedmyname's Avatar
No Heat
It won't be the fan clutch, mine is seized and I get great heat, way below freezing plus driving 70 mph. Won't be the t-stat either, after 45 min's of driving it'll be warm. If it isn't the heater control linkage, its probably a plugged heater core.
Old Dec 12, 2005 | 01:55 PM
suprathepeg's Avatar
I guess you don't live this far north.
Old Dec 12, 2005 | 02:02 PM
How did you get to that? Did you have to take the whole dash apart or just the blovebox?
Old Dec 12, 2005 | 07:00 PM
95yoda's Avatar
my heater was blowing cold air and i found out it was caused by anti freeze being low.
check your anti freeze level.
i topped mine off and bingo.
Old Dec 12, 2005 | 09:38 PM
trailrunner55's Avatar
i just flushed my heater core it was plugged just take the line off the fitting in the ngine bay on the fire wall ans put a hose up to it and blast away a huge chunk of this black crap coame flin out and now my heat works great
Old Dec 12, 2005 | 09:54 PM
No, I didn't take anything apart. It's right behind the ashtray, just stick your head down there and look up.
Old Dec 13, 2005 | 05:56 AM
90runnner's Avatar
...true, but it wont get too warm. im actually running around without a thermostat and it only gets to about 1/8 to 1/4 of the way up the temp gauge, which may look somewhat "normal". the thermostat on the 3.0 is on the bottom end of the engine, the lower radiator hose is connected tot he housing. 3 10mm nuts and pull it out and take a look.
Old Dec 13, 2005 | 08:12 PM
CoedNaked's Avatar
mmmmmmmmmmmmmmmmm............
