22re head shim
Old Nov 13, 2005 | 04:41 PM
shortboy2's Avatar
22re head shim
ok i have tore my 88 4runner down and found out i need to shave the head how much of a problem are the shim spacerfor the head going to give me down the road the blocks good and straight and it has low miles for what i have seen in here only 110000
Old Nov 13, 2005 | 08:18 PM
Yoda's Avatar
I did not have ANY luck with the shim. I used a "thicker" head gasket. It blew also (these lasted maybe 5K miles each). Then used factory Toyota gasket. Works good.
Old Nov 14, 2005 | 04:10 PM
shortboy2's Avatar
Ok I Have Talked To Toyota In My Area They Know Nothing About Thicker Head Gaskets They Say Go To Napa And Buy A Head Shim To Use When The Heads Been Shaved Im Not Sure Of Witch Direction To Go
Old Nov 14, 2005 | 05:52 PM
kyle_22r's Avatar
don't bother with the shim. if the head has been shaved a bit for resurfacing you will probably be fine.
Old Nov 15, 2005 | 10:53 AM
DudeBud's Avatar
this reminds me of a thread a few months back. the guy really wanted a shim. i think they are worthless unless there is a lot of materal removed
Old Nov 15, 2005 | 05:04 PM
superjoe83's Avatar
unless that motor got really hot, i doubt that the machine shop would have to take no more than .010" to clean it up, that much will not make a difference
Old Nov 24, 2005 | 01:49 PM
shortboy2's Avatar
thanks for all the help i have it up and running working on vacuum line now it up and running the first head had .050 cut off of it so i junked it second head only had the .015 cut off that i had cut so i used a shim and it working great so far ill just have to keep my fingers crossed thanks again for all the help
Old Nov 26, 2005 | 10:49 AM
ironroad9c1's Avatar
christ ,just get another head
Old Feb 23, 2007 | 06:15 PM
joeynational's Avatar
What is considered alot of material???
88sasturbotoy
Jan 30, 2026 01:57 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
jake_v
Jul 22, 2015 03:17 PM
ryerye13
Jul 14, 2015 08:27 AM
