EGR info needed.
Old Oct 22, 2005 | 02:05 PM
NathanBERG's Avatar
Question EGR info needed.
Okay I have a 1990 4runner v6. I am wondering if there should be a wire for the EGR temp conected to the EGR? I bought it used and it did not have one on there. I see the little hole on the side of the EGR valve but there is no wire hooked up. I have also discoverd a wire that looks to be unhooked and in the location of the EGR valve. Here is a photo of the EGR and wire.
Am I missing the Temp sensor? And if I am could this be why I am getting a code 71?
It is a Fed/Canada vehicle.
Witch leads me to another question. Why if it is a FED and CAN Vehicle would I be getting the code 71, witch is only for California Vehicles according to my Manual?
Dose anybody have a FED/CAN emissions Yota that has the temp Sensor wire?
Old Oct 22, 2005 | 06:46 PM
DH6twinotter's Avatar
I don't have anything in that hole on my '90 v6 either. I have a loose grey connector just laying around too. Either we both have problems, or there isn't any problem with that.
Old Oct 22, 2005 | 07:03 PM
NathanBERG's Avatar
ummm? Okay cool thx for your reply!! Have you ever got that darn code 71?
Old Oct 22, 2005 | 07:05 PM
Sure, no problem. I don't have a code 71 though.
Old Oct 23, 2005 | 10:27 AM
eric-the-red's Avatar
My Canadian 93 4Runner 3.0 V6 had a EGR temp sensor, but it was never connected to anything. It had about 3-4 inches of wire with a connector that wouldn't match anything else. And I also had that grey connector that you circled but it did not match the temp sensor connector.
The temp sensor threads into the hole, looking at your pic I can't tell if the hole is threaded or not. If it isn't then i don't think there is supposed to be a sensor in there.
Old Oct 23, 2005 | 10:35 AM
fillsrunner4's Avatar
I once removed this sensor from that spot. I drove around for awhile and eventualy my check engine light came on. I never checked for a code, I just plugged it back in and the light went out and never came on again. If you need this sensor I have one since im swapping out my motor for a 3.4. Let me know.
Phil
Old Oct 23, 2005 | 11:14 AM
ChickenLover's Avatar
Hey Nathan,
My rig aint canadian, but it certainly does have the sensor connected to your mystery wire.
Old Oct 23, 2005 | 12:59 PM
I wonder why some have this and some don't? Seems odd. What does the temp sesnor do anyways (other than read temp.)? Would this cause pinging? I'm going to check the local Toyota dealership and have them check my VIN to see if I need one.
Thanks for bringing this up! I had wondered about that hole a few time too.
Have fun all.
Daniel
Old Oct 24, 2005 | 01:55 AM
NathanBERG's Avatar
Phil
How much do you want for the Sensor? I want it !
Old Oct 24, 2005 | 02:01 AM
NathanBERG's Avatar
YEP it's Threaded.
Old Aug 24, 2011 | 04:48 AM
bduane's Avatar
where is the EGR on a 1989 22RE?can someone help with a pic?at low rpm's
in gear the throttle will kick out & back in when steady rpm but not while giving gas.this happens in every gear.(5 spd)
splangeland
Apr 6, 2024 08:14 PM
ToyotaMD
Sep 22, 2015 06:28 AM
runnermedic
13
Sep 21, 2015 05:20 PM
accuracy
Sep 20, 2015 07:44 PM
Boomer8404
Sep 10, 2015 09:01 AM
